Graham_Wright
For interest (and with his permission) here follows the correspondence on the topic I posted asking about crevice corrosion in 316 SS. (Bit long winded;- sorry together with some messy repetition).
> Tell me what's happened and I'll do my best to find the answer. Some of the
> issues that need to be identified are:
> Grade of ss
> What is the application
> Is the application above or below the waterline or a bit of both
> Did the problem occur above or below the waterline
> What is the ss in direct contact with
> What material is it bolted to
> What material is used for bolts/screws
> Was/is it to be welded
> What is it welded to
> What is the operating temperature if known. Eg, if a ss prop-shaft, is spent
> engine water being used to lubricate the prop-shaft bearing.
> That'll do for a start.
Point by point;-
Nothing has happened (yet) as the boat is not in the water. The interest I have is in the skeg shoe which carries the bottom bearing for the rudder stock. The designer called for a phosphor bronze casting but this is no longer available and I fabricated one out of SS.
The grade is 316L/1.4404 and the assembly looks like a boot. It is welded up from a 20mm thick "sole" with a skirt of 6mm plate formed to conform to the skeg profile.
The welding rods used were Silvercord variously and collectively defined as AWS A5.4-92 E316L-16, ASME SFA-5.4 E316L-16 and BS2926:84 19.12.3LR.
The shoe is (will be) sealed onto the skeg with a sealant to be decided and through bolted with 316L threaded bar. This bar could be extended to capture zinc anodes each side of the skeg (the prop is phosphor bronze).
There will be an electrical connection to the fixing bars down the inside of the skeg but whether this will be bonded to anything has yet to be decided.
The water environment will be salt, UK to start with and Mediterranean hopefully next year. Temperature range 12°C - 22°C?
Thank you for your interest and I look forward to your reply.
longer available and I fabricated one out of SS.OK, from this I am going to assume the part is permanently immersed in seawater.
the skeg profile.
AWS A5.4-92 E316L-16, ASME SFA-5.4 E316L-16 and BS2926:84 19.12.3LR. OK. Both the welded part and weld metal are 316L which means a low carbon grade. This minimises the formation of chrome carbide (potential corrodant) in the HAZ (heat affected zone) The formation of chrome carbide has the effect of reducing available free chromium. Chromium is the principal corrosion defense of ss. Below 12% chrome, ss corrodes much like regular steel, i.e. not very well. This situation can and does occur in the HAZ weld metal. Effectively, there are two dissimilar metals immersed in an electrolyte. Ideally, to remove this possibility the part should be heat treated by solution annealing and then passivated. The effect of solution annealing is to dissolve and disperse the chrome carbide rather than leave it as a defined layer in the HAZ. After heat treatment surface oxides and surface impurities all of which are potential corrodants should be removed by passivation. Whoever is doing the solution annealing should also be able to passivate. However, this treatment, while desirable, may not be practical or convenient, and use of 316L minimises risk of chrome carbide formation. If either part or weld metal were regular 316 you have no choice other than to solution anneal and passivate. Make sure that you sight material specs for both. No-one can tell the difference unless the metal is analyzed.
through bolted with 316L threaded bar. OK. same metal. This bar could be extended to capture zinc anodes each side of the skeg (the prop is phosphor bronze). It is always a very good idea to ensure submerged metal parts are electrically connected to a permanently submerged zinc anode. Zinc is an aggressive anode. As long as all parts are immersed in seawater and electrically connected an aggressive zinc anode will assist overcome pitting and scc (crevice) forms of corrosion.
hopefully next year. Temperature range 12°C - 22°C? OK fine
> Grade of ss
Point by point;-
the skeg profile.
