MJWB
I've read various threads around furling lines, including one I started about 4 years ago but not found an answer to where I am now.
Currently have 8mm line, though the drum is very full once all genoa is out. Jimmy Green article seems to recommend 6mm which plainly would not fill the drum as much.
8mm okay to handle for me (reckon 6mm will not be comfortable).
A Rotostay furler. The current furling line at 8mm appears too thick to fit through the holes in the furler drum and so whoever replaced the line last time has stripped away some of the outer, whipped it and just threaded through suffucient of the core to then be made fast as needed to the drum. A compromise to get comfort in handling perhaps.
My question is this. Any thoughts on how much this compromises the strength of the furling line?
