furlex
simonn
11 Aug 2002
Has anyone replaced a forstay with a Furlex fitted?.I have been told the whole spar needs to be dismantled.Can you not feed a new wire along inside the spar?.
Also am having trouble removing the cone from lower staylock fitting,It is jammed inside the Furlex part.Thanks simon.
bigmart
14 Jan 2002
Hampshire
Re:Colnbrook
I have a similar problem with my Colnbrook System. trouble is they do not seem to exist anymore & all the screws seem to be so corroded in they do not want to come loose. Anybody know got any data on this system?
Martin
Cantata
1 Aug 2003
Swale/Medway
Certainly can. Have to dismantle the bottom end a bit to get at the terminal, but the wire feeds in fine from the top, no problem.
Con_Brio
31 Oct 2002
I had the standing rigging replaced while my boat was out in Turkey (I brought the new rigging out from UK). I'm sure they simply fed the wire through. They had a lot of trouble fitting the rubber O-ring at the bottom of the Furlex and getting the circlip on over it. They botched it and I had to reassemble it all while lying at anchor. By the time I had done I needed a new circlip. I got on to Selden in the UK and they said mine was a discontinued model of Furlex and recommended that I replace the whole thing at a cost of £300+. Pretty poor stuff! I then wrote off to the parent company Selden in Sweden and got a free replacement circlip by return of post: more like it!
