Ian_Edwards
Strange title
I'm modifying a grab rail over a binnacle to take a MFD.
I've used 1/2" A4 SS weld stubs as the "bolts" to go through the GRP to make getting the cables through easy.
I've got some 1/2" BSP back nuts and M22 washers (22mm seems to be clearance diameter for 1/2" BSP pipe).
Two questions:
Will I lose very much strength by using back nuts instead of full nuts, will adding a second back nut help?
And
Is it possible to buy full length 1/2" A4 BSP nuts, I can't find them online at the usual suspects.
As a grab rail it could have a heavy person swinging on it in heavy weather, the GRP plus backing is 35mm thick and in its original form it had 16mm bolts with just a very small hole drilled through the centre, and full length nuts, I've cut the bolts off and had the weld subs welded on.
Two questions:
And
