Full fuel tank over winter ?
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
Near enough.....
Totally different. Diesel is liquid at room temperature and well above, with something like 10 - 15 carbon atoms in the molecule. LNG is methane with one carbon atom, a gas at just above -160C.
LNG is made by cooling the gas in a massive refrigerator. The GTL process is complex. Not being a chemist I don't pretend to understand it but I have had a bit to do with the huge variety of equipment used, pumps, compressors and turbines
wonkywinch
30 Jul 2018
Hamble, UK
Well it takes all I suppose .....
If they really said that .... I can only wonder where they got that rubbish idea from ...
Colour has no part in it.
Temp can slow it - but not stop it.
Stale ? Its diesel !! It has to be pretty bad to stop it working !!
As to additive to use - it depends on what you are treating. If its preventative - then near all will work. If its treating a system that has grown and collected the dead gunge - then you need an Enzyme based....
"Excellent diesel doctor" ???????
I don't have first hand experience of the bug but only called Chris as he came highly recommended. His business is based on cleaning diesel and tanks. He had every opportunity to suck air through his teeth and invoice me for his time. Instead he took a couple of litres of crud laden diesel from the bottom of the tank, explained why my particular boat was not at high risk of the bug (tank colour impacting light getting to organisms in tank). He didn't charge me a penny "no bug no fee". That's why I labelled him as excellent since the industry, indeed world, is full of people who will mislead and charge you for their time.
Why he'd give me misinformation I don't know, although they do say you get what you pay for and my cost was zero :)
Mark-1
22 Sep 2008
Did the crud in your tank look like the images of diesel bug you can find online? Dark grey sludge?
wonkywinch
30 Jul 2018
Hamble, UK
No, it was more like particles and rust/crud from 6-7 years of fuelling. Chris also pointed out the incorrect way Beneteau fitted the access on the fuel tank which supports my other findings in other parts of the boat how things were assembled in the factory.
Mark-1
22 Sep 2008
So you most likely didn't have microbial contamination, as he says.
His reasoning seems plausible and in my experience (small sample count) he is broadly right about black tanks and the placement of tanks in AWBs.
So the only controversial bit is "doesn't suffer". Perhaps he slightly missspoke and meant "are slightly less prone to" which seems plausible.
Refueler
13 Sep 2008
Far away from hooray henrys
Any 'living organism' is affected by light, heat and various other such as moisture / oxygen etc.
So it is possible that the rate of growth / death of bug may be impacted by dark / cool etc - but it certainly will not prevent it. It is also a fact that one area that is not mentioned is SRB ... Sulphur Reducing Bacteria .... a strain of 'bug' that doesn't give a hoot about it ... but as Sulphur content reduces in fuels - is less seen. SRB does not live in the oil - water interface by the way.
NormanS
10 Nov 2008
A properly designed fuel tank, fitted with a sump and drain, if used, will not have a fuel - water interface. This greatly reduces the incidence of the bug, or water or dirt getting anywhere near fuel filters.
RunAgroundHard
20 Aug 2022
Most yacht tanks, even with sumps, lose the benefit when healed over and riding waves. Any separated water soon mixes up. A sump in a so called “proper” design on a sailing yacht is pointless.
NormanS
10 Nov 2008
I don't think that you are correctly visualizing a proper sump. With a sump which ideally is deeper than its breadth, and which is drained regularly, there is no way that heeling will lead to water or dirt remixing with the tank contents.
B27
26 Jul 2023
I think many yavht tanks are 'properly designed' to sit on a flat shelf, because that's a requirement given to the tank maker?
If there's anything worse than having bug in a diesel tank, it could be having a leaky drain fitting at the bottom of a tank?
I don't think an opaque tank helps much, as I've seen diesel bug in stainless tanks.
RunAgroundHard
20 Aug 2022
I just don't think its usefulness is significant in a rock'n and roll'n sailing yacht.
