Fuel tank sender ?
Refueler
13 Sep 2008
Far away from hooray henrys
My Primor 24 has a 100ltr stainless steel gasoline tank each side of cockpit under the side decks. The filler and pipe is a straight affair allowing a stick to dip for fuel level.
Being under side decks - I cannot get to the top to fit fuel gauge sender. Stainless steel so side mounted external sonics are not much use.
It crossed my mind whether a removable vertical sender could be fitted into the filler pipe instead of the screw cap ? Care being of course to be sure no water sloshing down the side decks gets into tanks.
?? Is there anything to do that >>
Like this? https://www.fruugo.co.uk/screw-on-f...-wKdLHGL3X4hFKLjCzZDTWhRMdkDTPbhoCBPEQAvD_BwE if you can find one for your height of tank.
That would work if not a cap - but a threaded plug ...
The filler points have the standard marine press to lift the tab and unscrew plug ...
Like this but in metal :
My tank depth incl filler pipe is about 1m ...
On that site actually .....
Wema Fuel & Water Tank Sender S3 Screw Type - 40cm 0-190ohm
interesting ... just need to sort length and also how to unplug / unscrew to allow filling of tank ...
