Phoenix of Hamble
spent all day today trying to get a Ford Lehman 80Hp that hasn't turned over for 18months running...
A new starter was needed... tick... engine cranking over nice and quickly... no sign of any hesitancy on the very first push of the starter button, so no worries over seizure.
Now the fuel system.... arghh....
Nicely bled through the primary filters, secondary filters, and then the injector pump...
But would the bugger start....
I pulled the injectors, but no sign of any fuel on trying either the lift pump or the starter
Given that the lift pump filled the filters OK, I don't think that's the problem, so suspect the injector pump...
I guess it could be knackered rings, but i'd have thought that she'd at least have a little go at starting in at least one cylinder... but nada.
I'm loath to immediately blame the injector pump, as new ones are eye wateringly expensive.... maybe a leak somewhere?
....as an aside the water pump was also dripping quite badly, so that'll be another job!
Should add that she did take a swim 2 years ago, but has been run until thoroughly dry since, and ran happily.
What do you think of my injector pump diagnosis?
