santelmo
I have a project in mind to modify my fuel delivery system. I want to arrange the plumbing so that in the event of a secondary filter blockage I can quickly introduce a separate, filtered supply, pumped by a 12v fuel pump, either form an emergency supply of clean diesel or taking a tee from just downstream of the primary filter, thus bypassing the secondary altogether. I propose to use 1/4 turn ball valves. My question is would there be any damage to the mechanical fuel lift pump since it would be pumping against a blocked filter and beyond that a closed valve ? I am thinking here of ruptured diaphram.
