Only if you like oil/fuel dribbling in the wrong places.You lot like spending money, just bash a screwdriver through it with a hammer and that will give enough leverage![]()
This is what I use
Boa Constrictor Strap Wrench
I tighten the filter by hand and, if necessary, loosen it with this.
Have you not heard of Murphy's law.
Sorry Graham, I hadn't noticed you had already suggested this.If you don't have a strap wrench or other removal tool, you can punch a large screwdriver through the filter from one side to the other and use that as a Tommy-bar.
Messy but it works.
The local supermarket had a very similar one for €6, so that's what I ended up with - I see exactly what you mean. I was only able to get it tight enough to grip by using a spanner on the nut.I used to have one of the thin metal strap jobbies on the right. Couldn't get it to grip on even a moderately tight filter.
Which of these does the forum recommend, please?
If you put rubber tube over each of the 3 legs I have found it grips better.This is the best Oil Filter removal tool I have found so far, it has the advantage over strap or chain devices in that it can be use in more cofined spaces where both the other tools need more space to rotate them, it also grips the filter as you turn the wrench.
View attachment 95726 View attachment 95728
