tilmansailing
My fuel system has developed a leak, pumped about 25 litres of diesel into the bilge over about 8 hours running. When the engine is NOT running - no leak.
I have checked the water separator filter and the engine fuel filter for leaks, nothing significant.
I can see no fuel dripping from the engine while it is running.
While the engine IS running the rpm (a) does not respond normally to throttle action, at times I only get just over 2000 rpm but it occasionally rises to 2750rpm without any throttle movement.
I am home until 14th July, the boat is in France (St Martin, Ile de Re). When I return to the boat it will be Bastille day (big public holiday) so no marine engineer to consult right away on my return.
I am at a loss as to what to investigate next - any suggestions would be welcome.
Or, would someone advise me how to explain all this in French, to an engineer whose English is probably no better than my French?
