Kittycarter
A little help please.
I have a Sunseeker Comanche 49 with 250 met cruiser dtronic engines. Not sure if fuel filters are restricting power a little. Each engine has the fuel filter attached to the engine and two inline filters, the twist Delphi type. I have seen two fitted so you can switch between if one gets blocked but not two I line. Is this normal? Can't see the point as if first one gets blocked the second one is useless. I think they are different filtration levels.
