Fuel filter drain plug failed BSS inspection
TerryA
17 Mar 2019
Among the many items my happily seagoing boat was failed on by the BSS inspector was having a fuel filter with a plastic drain plug. Is that a bit extreme?
RunAgroundHard
20 Aug 2022
I used to be involved in charter yachts, coding. Fuel items which could melt in a fire and contribute further to the fire, such as plastic filter bowls and drain taps were not allowed. I don't know where BSS derives their rules or guidance from.
LittleSister
12 Nov 2007
Could you relocate the filter outside the engine compartment?
Yes, it is a bit extreme, but it's a scheme put together to reduce problems and dangers on inland waters, where some might argue the boat owners are on average less safety conscious/diligent than those who go to sea, and the scheme was developed with a lot of input from organisations and businesses who have everything to gain from more onerous standards and fewer problems, and nothing to gain through making boating cheaper and more accessible, nor inland waterways more accessible to seagoing boats.
There are occasions where (by accepting additional delay and cost) one can argue that you can achieve the qualitative requirement by means other than that specified in the inspectors' check-list, but rarely worth it.
I think it is simply an unfortunate fact of life.
TerryA
17 Mar 2019
I can't relocate the filter so I guess I can't argue with the requirements of the self appointed guardians if I want to play in their playground. But I wonder if I could sue the builder for fitting an item that is not up to a standard that did not exist in 1992 but is now being applied...
lustyd
27 Jul 2010
So what's the solution? The standard Volvo CAV filter has a plastic plug, is there a replacement plug? Would the glass bowl even survive that temperature/pressure?
rotrax
17 Dec 2010
South Oxon and Littlehampton.
Am I not correct in thinking that the BSS don't allow glass filter bowls?
Our Island Packet came from Gloucester Docks. It was registered with the Canal and River trust. It had a current BSS ticket when we bought it.
The OE Racor fuel filter had the optional metal shield fitted over the clear plastic inspection bowl. Brass drain plug. So, plastic was OK if shielded.
At the time that metal shield complied-2016.
Plum
6 Jun 2001
UK East Coast
No. The requirements are shown in post #4 and, as in post #15, plastic is OK if the whole filter complies with ISO10088, as does the compliant version of the Racor filter with a clear plastic bowl, a metal heat shield and metal drain plug/cock.
NormanS
10 Nov 2008
The advantage of the clear plastic bowl is that any contamination in the fuel, settled in the base of the filter, can be easily seen, and action taken. A metal shield over the plastic makes a nonsense of this.
This demonstrates a major difference between the safety priorities of sea going, versus canal and river craft. An engine stopping at sea as a result of fuel problems is potentially serious. The same thing happening in inland waterways is merely an inconvenience. The danger is that insurance companies et al may insist on compliance with regulations which are inappropriate.
RunAgroundHard
20 Aug 2022
Fuel filters with clear view sediment bowls, compliant with fire safety standards can be bought. The regulations already exist and as far as I can tell, so far, insurance companies are not requesting anything special in this area. I dont think this is the issue you believe it is. They are more expensive though.
This is fitted to my boat: -
Vetus Water Separator Fuel Filter CE/ABYC Max 140Hp (Vetus 330VTEB)
These filters fulfill all CE and ABYC requirements, relating to installation in the engine room. One of the requirements is that the filter can withstand a fire test of 2.5 minutes.
Plum
6 Jun 2001
UK East Coast
In addition to the vetus one above, the heat shield on the Racor filter does not stop you seeing through the transparent bowl
