25931
It is generally accepted that 2t outboards are thirstier than 4s but can anyone quantify ?
it all depends on the specific engines you are comparing. A direct fuel injected 2-stroke can be more fuel efficient than a 4-stroke. A small carburetted 2-stroke will be less fuel efficient than a 4-stroke.It is generally accepted that 2t outboards are thirstier than 4s but can anyone quantify ?
In my experience, modern Di 2-strokes do not use 2-stroke oil that is mixed with the fuel, they use regular engine oil.Some of the Di 2 strokes are very efficient and occasionally proven more efficient than certainly earlier 4 strokes. Especially the models that have very clever injection delivery. But you could argue that any claims such as this, might be offset by the cost or money spent on the 2 stroke oil required. A 2 stroke man, might counter that again by arguing matters around the cost being less than a 4 stroke when new…or less consumable parts routinely required.
? they don't mix the oil with the fuel (hence why they are direct injection) but they don't use "regular engine oil". Depending on the settings they might burn ordinary 2 stroke oil (in larger quantities) or burn a specialist DI oil more frugally.In my experience, modern Di 2-strokes do not use 2-stroke oil that is mixed with the fuel, they use regular engine oil.
The DI 2t outboards, like the buzzy mopeds tourists rent in Greece, are direct fuel injection, metered oil injection from a separate reservoir and use 2t oil. They can be very frugal compared to the old 2t carburettor engines most people are hanging onto for their tender.? they don't mix the oil with the fuel (hence why they are direct injection) but they don't use "regular engine oil". Depending on the settings they might burn ordinary 2 stroke oil (in larger quantities) or burn a specialist DI oil more frugally.
I'm looking for a 40hp. How old does petrol need to be to go stale ?What power range are you thinking about 2-10hp? 10-25hp? 30hp+?
My Yamaha F70hp 4t gets about the same mpg (and lph) as my previous Johnson VRO 50hp 2t, but it is a thirsty 70hp 4t as it is tuned for max power from the same engine used across their 50-70hp range. Typically 7mpg or 16lph cruising at 25kts.
At the bottom end of the size range, I wouldn’t be surprised to find that so little petrol is actually used by both 4t and 2t that it goes stale and gets replaced rather than being completely used up.
At the rate you will be burning it, you will feel like you are pouring it in from a bucket. Unless you are storing it between trips I wouldn’t worry too much.I'm looking for a 40hp. How old does petrol need to be to go stale ?
Never heard of any that use regular engine oil at all. Which models use that ? Any and every I’ve known will use injector specific 2 stroke oil. You sure ?In my experience, modern Di 2-strokes do not use 2-stroke oil that is mixed with the fuel, they use regular engine oil.
I’d suggest any of these you know of that have been fed regular engine oil, stop getting used asap. They won’t last long. Amazed they have even ran like that.In my experience, modern Di 2-strokes do not use 2-stroke oil that is mixed with the fuel, they use regular engine oil.
