Tim Good
I had to remove the insulation from the top of my fridge to access the chainplates. The insulation was a type of blue closed cell foam. It was destroyed getting it all out again. I’ve added armaflex up against the deck and at the back against the hull. The rest is open to options.
What do you recommend?
- I could try and buy more armaflex and fill it out with different thicknesses and try to remove any gaps.
- I could get some kingsman or cellotex and try to shape it into blocks like it was before.
- I could put some more 20mm armaflex on the bottom which would leave a gap in the middle and then foam fill it .... but that would be messy and quite permanent.
