French trawler/Submarine/Inquest
Slowboat35
4 Apr 2020
What a bizarre situation!
Is is surely abundantly plain that the visible and massive damage to the hull wasn't caused by snagged nets or anything remotely like it.
That was caused by a collision.
As there is no evidence or implication of a collision with a sub (an incredibly unlikely event, given the capability of modern submarine sensors) it must look as if the damage occurred in some other way.
Sybarite
7 Dec 2002
France
I agree that nets snagging could not cause damage to both sides of the hull. I suggest that the trawler was hauled under and was thrashed from side to side hitting rocks on the bottom in the process.
Slowboat35
4 Apr 2020
Both sides? Where do we discover that?
And how, exactly, does a trawler with nets towed from her stern get damage like that if dragged backwards ? I just don't believe it.
Nuclear subs simply don't (or very rarely) operate in such shallow water in any case.
"Thrashed from side to side"? Wow! That take some imagination! That doesn't look like rock damage to me. If it were there would be ample evidnce of rockfragments embedded in the hull.
I think you can be assured it was something else entirely. (That I very much doubt involved submarines)
dunedin
3 Feb 2004
Have you read the MAIB report about the recent near collision between a UK submarine at periscope depth and a Stena ferry in the Irish Sea. The submarine completely misread the speed and distance of the ferry - and the collision was only avoided by an extremely vigilant Stena watch keeper spotting the periscope and instigating an urgent swerve to port.
And the submarine skipper didn‘t even report the near miss, but eventually was directed by Naval HQ to surface and return to base.
So don’t rely too much on “modern submarine sensors”
bignick
10 Aug 2011
Poole
if the trawler was being towed behind a sub, how would it hit the bottom? The sub would be nowhere near it?
Daydream believer
6 Oct 2012
Southminster, essex
If you follow the links , you will see one picture showing the port forward side stove in. Then later there is a picture of the boat on a barge & the Stbd side is also stove in, in an identical manner. Seems odd that both areas of damage are the same; as if the boat dropped into a cleft in rocks on the seabed.
ean_p
28 Dec 2001
Humber
As mentioned in a thread elsewhere the likely cause of the collapsed hull plates is pressure as the fish storage room is / was likely a sealed volume.
