Andy744
Hi,
I'd like to run this past some of the more experienced motor boaters. (Which for me is almost anyone).
My boat was pressure washed and surveyed before I bought it 6 months ago and made 33kts top speed in the sea trials.
Six months later, my engines are short of my maximum RPM by 500 RPM (2500 is the max) and I can only make 2000 RPM and of course a much lower top speed.
So presumably there is fouling on the hull.
1. My question is, does fouling on the props & hull reduce the RPM that engines make?
The local mechanic looking after my boat tells me that It must be fouling that is causing the reduction in RPM. All other indications show there is no problem with the engines.
I just find it hard to believe that if you put 575 hp into a propeller that it won't turn at any speed you like!
2. Is my mechanic correct?
Thank you,
Andy
Sealine T50, with 2 X Volvo Penta D9 - 575
Thank you,
Andy
