Forward looking echo sounders
ianc1200
6 Dec 2005
Frinton on Sea
Has anybody experience of these? What do they achieve/how accurate etc? As I understand it, two transponders are needed, but would they see lobster pots or drifting fishing nets or purely changes upcoming in the levels of the sea bed?
I thought the sole purpose of forward sonar was for seeing the detailed topology of the seabed to aid with fishing rather than as a hazard detection system, as other have said I didn't think it would give you enough warning of an impending hazard.
I have one and mine has a forward that gives a display up and down but can also show side to side display.
Good for entering a rising channel or showing a narrow channel to save hitting the bottom or the side of a narrow channel
Brings back memories of a Seismic Boat I worked ... was a converted stern trawler.
On the bridge we had the displays for the FLS (Forward Looking Sonar) and SSS (Side Sweep Sonar)
When not shooting we often played with the gear ... must have been a real advantage to the fishermen ... but other than seeing blurred blobs etc - not much use for us !
Had one already installed in a P35.
As mentioned, not that much use on East coast mud and travelling at 25 knots, if whats underneath is sudden and hard its probably already to late .
No doubt it has its uses and admirers but the unit on the P35 was hard to calibrate and interpret and was eventually removed.
The no doubt latest versions might be much more useful ?
At least I can see my own anchor chain, the buoy lines. In fact, I use it when I'm in the archipelago, away from the official channel. There are a lot of rocks on this that may not be on the charts and it's really reliable there, I usually go under 6nm so I can react and stop.
I have platinum Echopilot fls
