Graham_Wright
What is the best way to cut it? It isn't Fomica proper, it is a substitutes but it seems very prone to cracking when cut with scissors.
Would warming it help?
Yes, but use a blade that cuts down, not up. The alternative is to cut oversize, fit it and use a router to trim the edgeDepends how big a piece but if practicable then clamping it to wood and using a jigsaw works
Glass cutter to score the surface .What is the best way to cut it? It isn't Fomica proper, it is a substitutes but it seems very prone to cracking when cut with scissors.
I was faced with how cut formica in a L shape for my galley. Fiddles all round so it had to be cut accurately.Never done but what about angle grinder with a 1mm cutting disk for steel?
That was my first approach. I found the edge of the cut was cracking. However, that was just with robust dress making scissors (best 21st present my wife ever had!).I thought youmight like to know what I am currently using to cut various shapes, large, small, curved and straight from a large sheet of formica at the moment.
They are a robust set of cutters from B&Q at £12.95.
So long as the cut is started where the blades meet, I am finding them first class.
An alternative, perhaps more controllable device, might be an die (I was faced with how cut formica in a L shape for my galley. Fiddles all round so it had to be cut accurately.
Decided to try grinder with 1mm disc. Like a knife through butter. Can there be a better tool for cutting formica ?
Another item to add to the long list of things that are easy to cut with add 1mm disc.
