My wife being hyper organised, I am not allowed to keep anything in those lockers. So it’s safety pins out, retained now on fancy spliced 3mm dyneema lanyards, flip the clutch on the backstay, wrap the fold side of the endless line and crank like crazyThis is my procedure:
1) Wrap the inhaul line around a winch. Remove and do it again getting the correct outhaul line this time.
2) Open a double cleat in a coaming pocket hidden under a forgotten half empty tube of soggy Pringles, last year's empty sun cream bottles, lost hats and itinerant Twix wrappers
3) Press button on electric winch to no effect. Press it again a few times in bemusement.
4) Realize you haven't switched on the isolator. Go below to resolve.
5) Press said button again to better effect this time for about a minute.
6) Close double cleat
7) Dispose of all the litter in the coaming pocket
8) Open a new Pringles tube, eat a few, and place in coaming pocket to become soggy and forgotten like the last one.
9) Repeat on the other side
10) Connect the beam brace wires with their pelican hooks wondering, as usual, if there are any real pelicans nearby to compare.
It takes a minute to do each side for the competent. Incompetence and distractions triple that time.
Understood... but I'm not sure why Med sailing requires large tankage and load carrying capacity.
Comparable to a Bavaria 32 (120L of water, 90L fuel), plenty of space for jerry cans. I’m guessing your human capacity is probably similar to or a little less than a Bav32, which whilst officially a “6 Berth” boat is in my opinion really a 2+2!The installed tankage on a 920 is 50l of water and 23l of fuel. That's not much for a hot place that might be windless. On my 35 those capacities are 140l and 80l which is still low for the size of boat.
Every day is a school day. Thanks.To take a 920 to bits for trailering. I did expressly say that it could be left assembled and ready if it wasn’t going on the road. Or left folded on a mooring, like ours is. You don’t suppose we go into Yarmouth harbour in the summer, nearly 25ft wide? We fold in the offing before going in, it’s 2 mins if Mrs C is on the handle, 1 min 30 for me. The 3 hours would also include mast raising, without a crane, and fully rigging up.
Angus, you have displayed worrying behaviour here, the authorities will be alerted, we have a psychopath in our midst.8) Open a new Pringles tube, eat a few, and place in coaming pocket to become soggy and forgotten like the last one.
That said a Bav32 is designed with med sailing in mind. A tri looks a lot of fun when sailing, at the slight compromise on comfort when not. If you lived ashore in the med and needed a boat for weekend / the off week of adventure it would be good. If you wanted to spend a whole season exploring the med, the interior would probably get frustrating.
In the end, buying a boat, a toy, is about smiles per pound spent. Everyone has their ideal, folding tris are not for everyone. I’d prefer it if folks could just deal with the debate without making stuff up. Honestly, it’s worse than owning an electric car. Your price ratio there probably holds through the Dragonfly range. You could spend 20k on a decent 26 footer, or nearly 80 on a 920. What you do depends on how highly you value the sailing experience.Probably about the same space and capacities of a DF35 with a 32' mono. Then what is probably the biggest issue becomes apparent - cost. A 2010 Bavaria 32 is about £45 to £50k. The same age DF35 is over £200k.
…..or fit a water maker…….was rafted with a JOG fleet, of SunFasts, last season, in Le Havre. They seemed to reckon on running with empty water tanks and living off their water makers. For weight saving. On their cross Channel races.You’d certainly be filling your water tank regularly. Though the solution really is to drink more beer.
I am racing next weekend. We’ll pump the tank out and carry 5l in a plastic container.…..or fit a water maker…….was rafted with a JOG fleet, of SunFasts, last season, in Le Havre. They seemed to reckon on running with empty water tanks and living off their water makers. For weight saving. On their cross Channel races.
Water makers need power, quite a lot of it = big batteries = weight, or a lithium conversion = expensive, but probably worthwhile on a Dragonfly, plus lots of solar to keep it all going (where are you going to put it on a folding tri?)…..or fit a water maker…….was rafted with a JOG fleet, of SunFasts, last season, in Le Havre. They seemed to reckon on running with empty water tanks and living off their water makers. For weight saving. On their cross Channel races.
The difficulty is that there is no such thing as "Med" sailing that leads to an ideal boat. There is only what you want out of a boat and the conditions you expect to use it in. First the Med is a very big place and second people "use" it in a variety of different ways. The dominant one for sailing boats is short term usage (charters/holidays) requires a boat with a large amount of space above and below decks, lots of gear for hot weather living, large engine as in most areas opportunity for long periods of sailing are limited either by the pattern of use (2-4 hours to the next bay/marina) or lack of wind. Hence the dominance in the market of the 10-14m boats from the big builders. A subset of this sector is the liveaboard who maybe cruises more extensively and wishes to remain self sufficient for longer. They tend to have the same requirements, but more storage, tankage, power requirements so often use the same types of boats but for 2 people instead of 6 and a big gantry on the stern to fit enough solar to support their lifestyle (read Baggywrinkle's many posts on kitting out his new boat).Understood... but I'm not sure why Med sailing requires large tankage and load carrying capacity. You're never very far from shops etc.
But as I've said, my Med experience is very limited, I haven't been east of Menorca.
For cruising we normally carry a round dozen large fenders. We leave most in the tender for racing, along with the light inflatable, spare fuel, wetsuits and paddle boards that normally get lugged everywhere. Still at up to 20kn. I do think Angus and I have been honest about the boats. Storage volume is massive, we have the outriggers too, we can get a paddleboard in its bag through the hatches. We also frequently venture out of lake solent. Really, anyone would think only a madman would buy one from the ill informed crap that is posted about them. And from you, Captain, I kinda didn’t expect it.Med moorings. Lazy lines. You are gonna need a shipload of fenders. Plus a passarelle. All add weight. Seen loadsa cats all across the Med and the occasional non folding tri.
Probably great in Lake Solent. Med though? Nah. In my opinion.
Guess you aren't familiar with med moorings, lazy lines and boats crammed in marinas often poorly handled. There are no pontoons to protect your fold up bits. There is a high chance of damage. That's notFor cruising we normally carry a round dozen large fenders. We leave most in the tender for racing, along with the light inflatable, spare fuel, wetsuits and paddle boards that normally get lugged everywhere. Still at up to 20kn. I do think Angus and I have been honest about the boats. Storage volume is massive, we have the outriggers too, we can get a paddleboard in its bag through the hatches. We also frequently venture out of lake solent. Really, anyone would think only a madman would buy one from the ill informed crap that is posted about them. And from you, Captain, I kinda didn’t expect it.
There's no cure for poorly handled, apart from s Bruce Roberts design. But otherwise, I am familiar, have moored in my share of med harbours in all sorts. Though mostly 8metre classics, delicate for other reasons.Guess you aren't familiar with med moorings, lazy lines and boats crammed in marinas often poorly handled. There are no pontoons to protect your fold up bits. There is a high chance of damage. That's not
ill informed at all. Nice boat, wrong place.
