Fog - To go or not to go
Shearmyste
16 Jul 2015
We had planned this morning to leave our winter birth in Ouistreham and head towards St Vaast to anchor for the night (first move this season), we had wanted a smooth run even through we are a sailing vessel (occasionally) so light winds were OK (2's and 3's forecast). So picture this only available lock out was at 0700 hrs so arouse at 0530 to be greeted with pea soup with the light house which is 500 meters away from the marina not being visible, so what did we do! went back to bed, we don't have AIS but do have radar. so here we sit looking at beautiful blue clear sky's thinking if I had my time again would I have made the same decision. My particular answer is an unresounding yes. The reason to post this was for us during the planning phase had not discussed the fog question and what we would do, and it may help others to ask the question even if there isn't an definite answer.
geem
27 Apr 2006
Caribbean
In the calm weather you describe we would have left. Radar would work well with no sea clutter to mistake for small yachts etc. In those conditions radar is king. AIS plays second fiddle in fog in my book as you see all targets not just the ones with AIS
Fr J Hackett
26 Dec 2001
Saou
Yes definitely I would have gone my only miss giving would have been small pot markers but with 20M visibility should not be a problem, I assume that you did have at least some vis.
GHA
26 Jun 2013
Hopefully somewhere warm
Great thing about cruising is not having a calendar :cool:
I recall rolling over and going back to sleep hearing the foghorn blaring every morning for a good few days in a row down the protuguese coast.
alant
30 May 2001
UK - Solent region
Leaving in pea soup fog, even with radar, is foolhardy, so you made the correct decision.
Malabar
20 Jan 2008
Isle of Wight
Safety is all about building in layers of protection. Even with radar, one mistake could ruin your day. If you really don't have to go, then revert to Plan B and make best use of the time. "Pressonitius" has been proven on many occasions to be a killer desease.
geem
27 Apr 2006
Caribbean
Jane and I would have left in fog one of us below watching the radar the other helming, we had a GPS repeater in the cockpit so navigation wasn't a problem.
We have stopped relying on instrumentation down below. We have 14" colour HD radar/plotter in cockpit under sprayhood plus 5 other Raymarine displays. We have all the data we need without losing a crew memeber to below. When in fog one gives a good lookout forward away from engine noise so they can hear anything ahead. The other is in the cockpit monitoring instruments whilst boat is on autopilot.
[3889]
26 May 2003
I'd rather be in here wishing I was out there than out there wishing I was in here.
Me too, but the latter applies at some stage to nearly every trip I make over 12 hours. But, strangely, I keep going back for more.
So how do you get get experience of thick fog when it forms in less predictable circumstances? Or do you wait for that to happen and hope for the best at the time?
alant
30 May 2001
UK - Solent region
If you meet a F10 whilst out sailing you have to deal with it, but would you set sail when a F10 is blowing simply to get experience?
No of course not, so why set sail when you cant see the front off the boat, just to experience fog?
Fr J Hackett
26 Dec 2001
Saou
If you couldn't see the end of your boat then absolutely it is prudent not to go but with visibility a little better and radar there is no reason not to, after all what dangers are there that you could not detect. It may not be the most pleasant of experiences.
geem
27 Apr 2006
Caribbean
+1 and its no where near as stressful as a F10......
michael_w
8 Oct 2005
Sailing in Nova Scotia killed the fog demons for me. To wait till it cleared would have taken 3 months ...
Never saw Whitehead Harbour even though we went there twice.
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
It occurs to me that some of the people advising going have not sailed in extremely thick fog, in which it really is not possible to see the bow of the boat. I took a short trip in these conditions, from Hellevoetsluis to Middelharnis, spar buoyed every few metres for half the way following the 2 metre contour. It was utterly disorientating even with radar and we found it almost impossible to steer a sensible course.
BobnLesley
1 Dec 2005
Aground in Yorkshire awaiting a very high tide
Go back to bed, every time.
Sailing in fog like unpleasant wind is what weekend sailors are forced to do, for livaboards/cruisers there's always, tomorrow, the day after, next week...
Our radar gets a test/check every month or two, but we've only used it for fog twice in five years; both occassions were towards the end of a multi-day passages.
Robin
30 May 2001
high and dry on north island
With radar AND confidence in using it and a relatively innocuous route ( ie not in and out of rocks, sandbanks etc. I would have probably left. The fog may well have been mostly prevalent on and/or near land rather than over the water farther out and might well be expected to burn off as the sun rises higher in the sky. However there should have been some indications in the local forecasts and outlooks and if your time is not critical 24 hours delay may not be a big hassle. In the past we have carried on in really thick visibility with fog 'patches' forecast that stayed with us all the way home across Channel But then too we have decided to stay put because of fog that cleared just as soon as the departure window had closed. The decision is complicated and individual and never the same answer every time. First and foremost is having confidence in the radar and gps/plottter and the ability to use them correctly for both navigation and collision avoidance, merely having a display out in the cockpit is not enough as it takes practice to interpret radar for collision avoidance correctly. AIS is useful but not alone in my opinion. MARPA too is also useful but not perfect especially without being interfaced with very rapid and accurate course/heading sensors. In thick fog an autopilot beats a helmsman hands down especially if said person is trying to steer by looking at a radar screen
Moral here, is use radar etc in clear visibility often to test, practice and gain confidence for when the real stuff arrives.
jordanbasset
31 Dec 2007
UK, sometimes Greece and Spain
It was the fog horn in Povoa de Varzim that did it for us. We were there for 5 days and the fog never seemed to lift and the fog horn, which was an air raid siren type, never stopped. It was like mental torture, almost impossible to sleep. In the end we left in fog, we had radar, about 3 miles off shore it was completely clear.
alant
30 May 2001
UK - Solent region
You get a lot of fog off Daytona Beach then? ;)
