Fluxgate compass
PabloPicasso
12 Feb 2010
I've just joined my good pal for a summer cruise. His Old Raymarine fluxgate compass has failed, and now the autohelm won't steer.
We could try and find a repacement on ebay.
But is there a new replacement that would work easily?
Many thankss
lustyd
27 Jul 2010
In theory as long as it's ST1 it'll work. You could also use a ST1 to N2K/STNG converter and start the process of a full upgrade, giving you access to any modern compass. If no intention to upgrade I'd go for eBay. The one I sold there last year was essentially imaculate as I imagine most will be when removed.
PabloPicasso
12 Feb 2010
Pardon my ignorance. What is ST1?
Martin_J
19 Apr 2006
Portsmouth, UK
Remember that they always rattle... so a rattly noise if you shake it gently isn't necessarily a failure.
I guess you're sure you (the guest) didn't just bring something magnetic aboard ..
Whereabouts are you..? Someone nearby might have a spare..
pandos
15 Oct 2004
Ireland, (Crosshaven)
Many thankss
There is a test for these which may reveal it is a wiring fault rather than a compass fault.
Also I think some faults can be fixed if you have good soldering skills and eyesight...
I swapped mine out a few years for one that came from the for sale section..
PabloPicasso
12 Feb 2010
Currently in Cowes Haven. Heading to Poole tomorrow.
If anyone can help....
PabloPicasso
12 Feb 2010
20% down on tested ohms values, sadly
PabloPicasso
12 Feb 2010
Currently in Cowes Haven, heading over to Poole
PabloPicasso
12 Feb 2010
What, and how, do you do the test?
PaulRainbow
16 May 2016
Suffolk
Raymarine Fluxgate Compass Test
Multi-meter should be set to:
(a) Resistance scale
(b) 200 ohm scale
The following procedure should then be followed:
1. Disconnect the transducer from the system.
2. Connect one multi-meter lead to the red wire and the other lead to the green wire and a reading
as indicated in the test data table should be present.
3. Follow the above procedure for all the color combinations indicated in the test data table.
4. If all readings match those indicated assume the compass transducer is functioning correctly.
Compass Test Data:
Compass
Cable Colors
Resistance
Measurements
Comments
Red to Green​
4 ohms​
Measurement is taken between the two colors​
Red to Yellow​
4 ohms​
As above​
Green to Yellow​
8 ohms​
As above​
Screen to Blue​
8 ohms​
As above​
All other combinations​
Open Circuit​
You are looking for a short or open. A +or - 2 Ohm reading is allowed.
PabloPicasso
12 Feb 2010
Yes we did that. Approx 20% lower on each test.
So that seems to be within allowed limits?
Sticky Fingers
21 Feb 2004
I found the problem after fixated perseverance. A broken wire, easy enoufg to reconnect once located.
But of course, it was hidden from view behind cabinetry in an inaccessible corner.
Boat is steering itself beautifully now.
Result. They do always seem to be hidden away, presumably to stop people randomly storing magnetic-field-affecting objects nearby.
PabloPicasso
12 Feb 2010
Therw was no space to be able to reach in and get my head in and see it at the same time.
I used my phone as a mirror, and had to reach in at full stretch with one arm, strip a bit more cable, push open the connector block, and get the cable into the right position to make a good re-connection
As easy as many other jobs aboard a boat.
