Floating dock which way ? Mast derrick ?
What difficulties do you come across when launching and recovering your vessel?
  • Car gets Stuck
    Votes: 0 0.0%
  • Trailer gets stuck
    Votes: 0 0.0%
  • Vehicle gets wet
    Votes: 0 0.0%
  • Adverse weather conditions
    Votes: 0 0.0%
  • Tidal influences
    Votes: 0 0.0%
  • Launch point access
    Votes: 0 0.0%
  • Sand into vehicle
    Votes: 0 0.0%
  • Salt water corrosion
    Votes: 0 0.0%
  • Total voters
    0
Derrick is no doubt the simplest arrangement to use
The guy lines must be well anchored.
There is some description of a homemade timber one here
I can remember seeing a timber pole with hand winches used for steel erection 50 years ago. They lifted steel trusses using timber the size of a telegraph pole.
Yes, you're probably correct. I just looked at the way you had drawn the examples and made my judgement based on those proportions.
Sorry, if I assumed that you had posted something that was accurate /forums/images/graemlins/grin.gif
No prob ... originally we were thinking at about drum size for width ... but then realised later it's a bit narrow. So increased the width a bit. My apologies that I failed to let people know ... you can appreciate what with running companys' and doing the house / pontoon stuff - my head can be spinning sometimes. Believe it or not I am also ill ! No joke ... I am ! But I'm one of those daft people that don't stop.
Excellent link.
The diagram you show - I would not put the guy lines at the points indicated (named as 'swing-lines' in the sketch) ... I would fix them to the head of boom as we do on ships - it reduces the effort needed to swing a boom under load and also reduces the stress on its fittings. But the idea is good.
I was on for sheelegs - but was losing the ability to swing the boom to place dinghy to side after lift ! With this arrangement I regain the arc of swing without the need for substantial pile driving of king post - I'd completely forgotten about Scotch Derricks with base frames.
The basis of the design is to have scantlings of timber that are easily handled / erected but stayed and supported like a mast against bending etc. The timber providing compression support.
Back to drawing board and thge Pros & Cons sheet !
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Get well soon.
We'll allow you to take a break over the next 4 days.
I wish I could ... Easter may be a holiday - but ships do not stop and oil traders want their blends etc.
Tomorrow once I get my guy back from his night duty in town ... think he found a lass !! we carry on ... most likely - him with a hangover but beeming smile on his face ... me feeling like a tank has run over me !
