Stu Jackson
Slow cranking means poor electrical connections. I agree, check them out.
Many thanks all for the very welcome advice.
Next to check are the valves and/or the injectors. Fuel is definitely getting through, but I hadn't considered that it might have gone off.
I'll keep you posted
Cheers
If you keep turning the engine over make sure you aren't filling the exhaust with water, it could end up back-filling into the exhaust valves depending on the geometry of your installation.
Just to reinforce this, a friend of mine kept cranking his engine ... didn't fire so no exhaust gasses ... the exhaust system filled to the point where the seawater backfilled into the cylinders ... total fluid lock ... bent everything ... new engine required :nonchalance:
Sadly, this would appear to be the case.
Engineer took the head off yesterday and and pistons, rings, and valves are all knackered. .........New engine was his recommendation,
So he undid the big ends and took the pistons out to inspect the piston grooves and for ovality?. He dismantled the head to check the valve guides and state of the valve seats for pitting/grooving?
If your 'engineer' just condemned the engine by taking the head off then I recommend you find a proper engineer and ask about his qualifications to be called an engineer. Yours sounds like a mechanic who can only replace with parts off the shelf, not overhaul them and does not know where to go to get bespoke oversize piston rings made for example. Nothing wrong in that per say, its the way of the modern world in general, but older engines need more engineering knowledge and skills.
Engines of this era are very basic and should run for decades, unless the bores are really scored etc the engine should be capable of being rebuilt by someone who knows what they are doing.
To decide to replace or repair will depend on what you want, were you happy with the power/fuel consumption of the current engine, how quickly do you want to get going etc.
Brian
