pmagowan
Is it old fuel? At the end of the day diesel engines tend to be quite simple. If it turns over then electrics are generally fine. Then you need clean fuel and compression to get it to fire. It almost always comes down to fuel. Either a leak in the fuel pipe, a clog, contamination etc. It shouldn't be too difficult to pin it down. You can 'feel' compression when you turn the flywheel or you can loosen an injector to decompress a cylinder. I only speak from experience and some amateur engine rebuilding, just be systematic and you will generally find the problem.
