Flag Alpha at night
peterb
Radlett, Herts
No problem. Colregs rule 27(d) gives the night signal for underwater operations as the normal power vessel lights for a vessel of her size, plus red-white-red all-round lights in a vertical line, plus two vertical greens on the safe side to pass and two vertical reds on the dangerous side (i.e. the same lights as a dredger).
But then 27(e)(i) says that if the size of vessel makes it impractical to show those lights, then it should show just the red-white-red in a vertical line. And, 27(e)(ii) also gives the day signal for a small diving vessel; not just flag 'A', but a rigid replica of flag 'A' not less than 1 metre in height.
Incidentally, if your query arises from Current News 264, the question wasn't raised at a RATS meeting, or the same answer would have been given there.
alant
30 May 2001
UK - Solent region
probably lights showing the vessel is "restricted in her ability to manouver" with maybe additional lights indicating "engaged in dredging or underwater operations"
Boatman
18 Jun 2001
Where I am
An interesting discussion with divers of the PADI ilk discovered that there are a number of issues with "I Have a diver down" the PADI flag is not internationally recognised yet many divers didn't know flag Alpha.
How can this situation have come about? And I certainly only recently learned of the PADI flag
ianwright
Home: Peterborough, Mooring, Heybridge Basin
PADI,,,,,,,?that must be since my time, I never was big on acronyms, I had trouble with SCUBA, nasty Americanism,,,,, Bear with me, I trained under a CPO Clearance diver,worked in hand pumped Seibe Gorman Standard dress before we had Aquadine and Ratcliffe hats and my Saturation Cert is number 13,,,,,,, :)
