Das_Boot
Re: Bronze seacocks in steel hulls
My point re: the undercover painting was that is what Awlgrip said. To get the perfect finish and meet the exacting standards set by Awlgrip to satisfy their gaurantee. I only posted the Awlgrip blurb. I have just orderd arround a £1000 worth of Epigrip. It is more tolerant and they have a system that allows the hull to be primed even if it is still wet from the slurry blasting. Whicking is still a problem if you are going to use a brush or roller to paint or to dry off the boat prior to painting. It is also a problem if you allow dust to settle in the wet paint and the profile of the dust is higher than the coating you are applying. Water will be whicked to the substrate by the dust particle. I still maintain the this is the reason that rust appears in the middle of nowhere on reasonably newly painted surfaces.
