Elessar
Bought the medium sized one which is right for a boat of my size.
It comes with a thread top and bottom and a hole down the middle.
It comes with a mast bracket (no good for me of course) and a flush threaded bracket that you can put on a flat surface and just screw the reflector into it. As the threads are the same as VHF, TV and GPS aerials, you can put, say, a GPS on top of the reflector and run the cable down the middle. Very neat.
But if I put mine flush on the radar arch it will obscure my own radar.
I have a hoop over the top of my radar that has all sorts of clutter on it, but I could put the reflector where the GPS receiver is and put the GPS receiver on top of the reflector.
But the reflector has male threads top and bottom. You can get all sorts of devices to raise GPS and other threaded things, but they all have male on one end female on the other which doesn't help.
So - I either need a collar with female threads either end. It would need to be metal not plastic as the reflector is quite weighty. Where could I get one of these?
Or I could screw the flush bracket to the top of the radar dome itself (raymarine, 4kW analogue). Can anyone see any harm in this? (I would make sure it was bolted with short enough bolts not to foul the whirly thing whatever that's called)
Thanks!
Thanks!
