RJJ
Hi all. Today's teaser, assistance and advice gratefully received.
I am keen to install a manual seawater pump to the galley. Ideally this would use existing through-hulls and be easy to fit to the Corian worksurface. I have four specific questions, but any observations are welcome
1. is it feasible for the galley inlet pump to share a skin fitting with the galley sink drain? Using a manual diverter valve, or a more intelligent solution ?
2. if not, is it feasible to share with the engine raw water inlet?
Otherwise it's a new through hull. At least I know how to do that, having fitted eleven of them this spring ?.
Then
3. Hand pump or foot pump? I presume the former is slightly easier to fit, since I have to drill a hole anyway through the Corian worksurface?
4. Any tips on drilling out the Corian? There are already cracks in it from the previous ownership, as it's quite thin (laterally) around the fridge, so I am a bit sensitive to doing it carefully.
Then
