Iain C
Thanks to a £10 boat jumble bargain, new sprockets/chains, and some helpful forum members, I now have an SL Hyspeed ready to go on my foredeck. Boat is a Sabre 27, so there's just a bronze stemhead fitting, rather than a roller. At the mo, behind that, lives an aft-facing hawse pipe, and behind that, a samson post which takes the loads of the swinging mooring where the boat is usually kept.
So I was thinking of the following setup...
-Install the windlass between the bow fitting and the samson post (distance from bow not critical as the anchor stows on deck rather than over the bow)
-Cut a new hole in the deck, as far back as possible whilst still allowing the gypsy to drop the chain straight down the "hole" in the base plate of the windlass, down into the chain locker below (the chain needs to be running as near to the chain locker/forecabin dividing bulkhead as possible)
-Use a snubber when at anchor to take the loads. Drop spliced loop over samson post, hook end over the bow. The windlass itself may "deflect" the straight run slightly, is this a big problem?
-When on the swinging mooring, I will modify the top end of the mooring setup so that I have a large loop of plastic covered chain that I can drop over the samson post. Plastic should stop the chain chewing the windlass too much.
Questions:
-It's possible that with careful positioning of the windlass, the run from the samson post will be fair (I could also move the samson post slightly off centre to help with this. However has anyone else had this problem and how did you overcome it?
-I understand that the gypsy needs to be in line with the bow fitting, rather than the windlass being central. However, as my bow fitting is essentially two sheaves, with the forestay on a central divider, is it OK to take it a little off centre so that the chain tends to rub the stbd side of the sheave, i.e. the one without the forestay clevis pin?
-If the chain is dropping straight down into the locker, I presumably do not need any kind of stripper?
-What can I do to keep the water out of the hawse pipe? My 90 degree pipe obviously won't be any good, but I somehow need some kind of cover that I can slide over the hole in the windlass that the chain passes through (see pic). Any thoughts?
Thanks!
Questions:
Thanks!
