smeaks
I am fitting a windlass options
1) fit seperate battery locally in forecabin with isolator from the charging system then limit the run on the motor control feed cables. What diameter cable would be needed to charge it?
2) run the cables direct from the house battery but utilise a larger cable to limit the v drop...... again what size of cable ....? boat is 31 ft
thanks
smeaks
thanks
smeaks
