pvb
I am about to fit a Vetus Strainer. Vetus recommend that is a minimum of 150mm above water level but to have it an accessible position I need to have it at 300mm. I assume that the additional height will not matter?
The extra height won't matter. Be careful that you plumb the strainer correctly. The inlet pipe ends close to the lid. This means that when the engine is turned off, the strainer is more or less full of water - this is the water which primes the pump when you next start the engine. If you plumb it the other way round, you'll have problems.
