jimi
We're off to the Baltic (hopefully) this year so need to fit one! Any experience of fitting an S38 with one would be appreciated. Is this easily done by oneself or safest to get someone else to do it?
My favourite boat building job lol. We use Tek Tanks exclusively as they are a fit and forget. They make one for your boat http://tektankslimited.com/moody-s38-waste-tank-mdys38wastecomstps-996-p.asp
A little dear but it is the proper job. Nice boat so keep it nice with a proper install![]()
You probably know already, but if going to Finland or Sweden you need a system that has a deck fitting for quay side pump out, as discharge to the sea is no longer lawful.
That is daylight robbery!! Looks as if its designed to fit the hanging locker in the aft cabin. Might be cheaper to fit a standard one in the cockpit locker.
The best is not necessarily the most expensive, sometimes it’s the simplest and cheapest.The tank is only part of the cost and expect once you investigate thoroughly you will find there is no "cheap" effective solution. Moreover, you need to fit the "best" as the last thing you want is problems with a system in your boat that holds anything up to 70 or 80 litres of human waste!
Not only do they seem to cost a lot to fit but once installed can lead to all sorts of issues with routing so if you can you might see if you can look at some actual intalations. Our last boat didn't have one and was simple but with an integrated one on our new boat it just seems to be a liability as the design seems to be created to cause blockages so it's not just the tanks to worry about. One of the improvement jobs is to fit a bypass so the tank can be avoided where permitted.Many thanks, lots of food for thought. Need to start measuring and explore routing options.
I am only passing on my experience of holding tanks having fitted two to existing boats and been through the options and the ways of trying to use a standard size tank. The Tek Tanks are the very best and having a custom tank made enables you to get the maximum volume with the minimum disruption to the rest of the boat. Retrofitting is invariably difficult with a boat that was never designed to have a holding tank.
+ 1
Tek Tanks designed a tank for us and it just works without any problems at all and with the CA discount it was a very reasonable price.
The planned discharge ban discussed in that link concerns Baltic international water and is primarily aimed at cruise ships.
Finland has had a toilet sewage discharge ban within the 12 mile zone since 2005 and Sweden adopted the same kind of regulations 2015.
