rmcnabb
New Member
What's your budget?
Don't worry about it. I have owned 2 Bavarias (a 37 and a 33) both with in mast by Selden and sail single handed. Would not change back. Single handed (or short handed) sailing is all about knowing your limitations, forward planning and setting up your boat so you can deal efficiently with the main controls. Once you get outside harbour size becomes less of an issue - the main challenges are in mooring and berthing. So, in mast (or really well sorted reefing from the cockpit and a stackpack), winches accessible from the helm, a good autopilot, electric windlass and a bow thruster if you regularly moor in tricky situations.in mast furling is the only thing kind that scares me if wether turns bad and you can't furl in when you need it.
Sorry when I wrote that I'd missed that you may not be UK based so probably less of a problem!yep. I'm looking for VAT paid sailboat.
It really isn't. I spent 10 years on a boat with only the sheets in the cockpit and most of my sailing was solo. My new boat has all lines to the cockpit but is harder to sail solo for several reasons when compared to the old boatSingle handing then reefing from the cockpit is essential.
Stuffy little cockpit with 4 in it.A 32 foot sister of the International H boat. With her self tacking jib easily managed singlehanded or for the inexperienced. Good sailing performance. I regularly cruise mine on the Westcoast of Ireland and ScotlandView attachment 109133
What's your budget?
‘Sailboat’ is the nautical equivalent of ‘bathroom’ as a euphemism and if you are not American marks you out as someone addicted to Netflix.
There are plenty of sailing boats of all sizes in the Baltic but anything much over 38’ may limit the moorings available, especially boxes, though vast boxes exist in some places. There are handling issues involved with sailing in and out of Baltic harbours and larger boats can require experience to avoid difficulty. For someone with little or no experience, a boat in the low 30s range will be quite enough of a handful.
As for choice, any boat from a major builder will do the job. There are really very few ‘bad’ boats, so much of the choice comes down to accommodation and just whether or not the boat appeals to you.
you might perhaps consider an Artekno H 323. There are 3 for sale in Finland at the moment:
www.nettivene.com/en/h-323
Another possibility is H 35 by the same builder
www.nettivene.com/en/h-35
Naturally I would recommend a Bavaria, and of the early 2000s models the 34 is probably the best all rounder, but 36 and 38 are also worth looking at, although the 38 is actually 40 and a much bigger and more complex boat. If your budget runs to it the 2012 on 33/34 is in my view one of the best and the newer rigs with smaller headsails are much easier to handle. Hanse are similar in this respect with self tacking jibs - the 342 hit the sweet point at the time as did the later 325 - that was my second choice after the Bavaria.
Hope this helps
You mention you have day skipper qualification.
Who you be sailing with friends, girlfriend, wife, or wife and family.
I am aware of a few with the wish to go sailing start but due to lack of comfort or facilities on boat end up sailing on their own or give up.
For this reason after dinghy racing with wife and some sailing holidays in Greece we started with a modern 36' and now have a 43' which we have lived aboard for last 12 months!
I suggest if you want family to sail with you a priority is to introduce them to sailing and enable you to try out a few boats by doing a sailing holiday in Greece.
You will have a better idea after then whether you want a size of boat for a family, for just 2 or for solo sailing.
Its a factor a number miss in fulfilling their dreams that is why the majority of sailors are men!!
I spent my first 30 years sailing 6 and 7m boats and the last 10 years sailing and now living on board my 10m boat. Sailing small boats was fun, taught me a lot and was very cheap. A 10m boat is big enough to live on, go anywhere in the world and feel comfortable while still having, on my low income, manageable cost of ownership. And easy to sail solo or with up to 3 crew. Any bigger increases luxury of course, but also costs.
Headroom can be a problem on a smaller boat though. Its amazing how you adapt but I occasionally hit my head in doorways even after 10 years. And the bunks are a bit on the short side. Boats at the shorter end of the range you mention are likely to be a bit slower than longer boats, too, though sail area and hull design will be key factors.
Just don't recognise this, about either size or inmast/controls from the cockpit. Why do you need to go running to the mast to raise sails, or worse still to reef. Reefing is required when things get a bit lively and the last thing you want to do is go to the mast when on your own, particularly in a small boat. A larger boat is usually more stable and forgiving, with the right gear (bow thruster) and good planning berthing is manageable. Those who have problems with in mast it is usually because they don't read the manual. They are simple devices and allow you infinite adjustment of sail area (like furling headsails) from the comfort and security of the cockpit. Once you have sailed a well set up boat such as I describe you will appreciate the benefits - particularly if you are a pensioner of long standing who wants to keep sailing as long as possible.I agree with lustyd here. Hoist and reef at the mast would always be my advice. I am not a fan of inmast reefing either as have seen many cruisers having troubles with theirs and to fix them they allways seem to have to call out an expert, expensive and often inconvenient . Keep it simple hass always been a good strategy to adopt.
As others have said better to start out with a smaller boat being easier to handle and manage particularly in say berthing.
I dont quite agree with all of Tranona's points but he has got it spot on when he says - "Single handed (or short handed) sailing is all about knowing your limitations, forward planning and setting up your boat so you can deal efficiently with the main controls.
