WorcesterMan
Thank you, that's really helpful. As it happens, I've just spoken to the other owner in Parkstone and it was him who raised the question about leaving it floating on the mooring with everything retracted. I think you have reassured me on that point.We had a good friend with the lift keel 27.7 around 2010 and having a smaller lift keel Hunter Delta 25 at the time I was very interested in the design and went on the boat a few times. I recall that it has most of its righting moment in a lead bulb at the end of the keel that can not be retracted into the hull. This means that on a mooring with the lift keel up it still has pretty good righting moment and in the shelter of Poole harbour I would not hesitate to leave it on a mooring with the keel up. The Hull shape also has a fair amount of hull form stability. We used to leave our Delta 25 on a drying mooring in Chichester harbour with the keel up and that was considerably less stable than a first 27.7!
One thing you want to avoid is hitting the bottom with the keel half up, this wedges the keel in the slot and makes it very hard to free it. Our friends discovered that the hard way!
I know of at least 1 other lift keel First 27.7 that runs out of Parkstone so you may be able to find the owner of that boat if you try for more information.
A more nagging question is how flexible the boat would be when cruising: the draught is 2.15m with the keel down, and I'm advised that we shouldn't be sailing with it up. We sail in the Poole -> Solent area and that would mean that we need to down sails and start motor very early. We have had great fun sailing our Beneteau First 211 inside the harbours at Poole and Christchurch and I wouldn't like to lose that freedom.
