youen
Does somebody know how to have a look to the hydraulic jack used to lift the keel.thanks
The 27.7 had an electric hydraulic pump mounted inside the cabin with a manual pump handle back up option. This operates a hydraulic ram which I think from memory was mounted inside a vertical brace tube at the front of the salon table. This then is connected to a wire strop which goes round a deck mounted pulley and can be seen going through a slot in the salon table to attach to keel. I think the ran works at a loss so that the movement of the keel is double the ram stroke. The Salon table hinges open to reveal the keel box. The keel when lifted is visible inside the cabin. It can only be lifted the maximum stroke of the ram. There is no need for a limit switch. The lowering is done by solenoid valve and is restrictor. The design is really only suitable for either lifted or lowered positions. There were issues with problems of the locking mechanism failing on early boats . It is a while ago but I seem to remember they had straps that had to be bolted across the top of the keel once it was lowered. Straps and threads were stripping or failing. The Keel is a composite structure with a lead bulb which is a bit of an unknown quantity. I came to the conclusion that the lift keel version was a liability rather than an asset. Having that weight hanging on a wire with no secondary locking is an accident waiting to happen. I rejected it as a practical trailable lift keeler suitable for a typical sheltered half tide berth or anchorages in our area. Especially as like the Anderson it needs legs to dry out upright except in deep smelly mud. I will possibly meet the owner of one this weekend. I know he has had to replace the rudder which had also failed with horizontal crack just below the lower pintle on both sides of the laminate. Possible design weakness here also. Everything was very flimsy on this boat. I didn't like the way the cockpit side flexed when you braced a foot against it to pull on a sheet.Does somebody know how to have a look to the hydraulic jack used to lift the keel.thanks
https://www.google.co.uk/search?q=f...hWLL8AKHbc7CV4Q9QEIXDAG#imgrc=FepdIfPZN-eN9M:Manyt thanks all I understand how it works but want to know if its easy or not to check thé hydraulic jack and the lifting strop.its incroyable in France its seems that nobody check this importants parts.I know that some boats had lost their rudder after the failure by electrolysis of thé lower part or the rudder hinge mix of alloy and stainless under waterline
It isn't a drying mooring, but it does need the keel and rudder to be retracted for the mooring. My question is whether the boat is stable in that position.This design requires legs to support the boat when drying. It needs these to protect the saildrive and rudder and support the boat as it has a large external bulb.
I would suggest this very lightly built boat is only designed for occasional beaching in pleasant conditions with legs it is totally unsuited to a permanent drying mooring.
We had a good friend with the lift keel 27.7 around 2010 and having a smaller lift keel Hunter Delta 25 at the time I was very interested in the design and went on the boat a few times. I recall that it has most of its righting moment in a lead bulb at the end of the keel that can not be retracted into the hull. This means that on a mooring with the lift keel up it still has pretty good righting moment and in the shelter of Poole harbour I would not hesitate to leave it on a mooring with the keel up. The Hull shape also has a fair amount of hull form stability. We used to leave our Delta 25 on a drying mooring in Chichester harbour with the keel up and that was considerably less stable than a first 27.7!It isn't a drying mooring, but it does need the keel and rudder to be retracted for the mooring. My question is whether the boat is stable in that position.
