dankilb
I agree that the Maus does look impressive in the test (and should be better engineered/supported than the cheaper, unbranded, alternatives). Certainly packs a punch for its size. Less so for the price (about £80 in the UK, it seems), but you can't have it all...!Yes... and at the same time no, only so-so.
One down side of a pyrotechnic type is that you only have one go; the fire needs to be out within the burn time. There are pyrotechnic units with much longer burn time.
- Dry chemical was much, much faster. The fire was out before the firefighter was even in the camera frame!
- Notice how the flames actually spread first in the class F fire at the end. That is characteristic of water mist. In a bilge space, it may well have just moved it around.
- These are simple, exposed fires. What of the actual cases, where the fire is hidden behind the engine?
- I've done this test with a pyrotech extingusiher. It was more like the dry chemical in terms of speed, with a lot of smoke but little residue.
Maus. Look at 1:09, same standard petrol test
And look at the tiny size of the Maus, perhaps 10-20x less than the size water mist extinguisher we are comparing it to. It is batting way out of its weight class in this comparison.
Not sayin' I'm a Maus fan, or that I would sail with just a Maus (I would not), just trying to present something the group seems less aware of. The technology is just gaining traction, so the benefits, weaknesses, and best uses are still up in the air.
For comparison, our new 'main' extinguisher with the aforementioned 'FIA' motorsport-spec foam that doesn't freeze down to -20°C is the same sort of price - but that is in shiny stainless!
2.4 Litre AFFF Hand Held Fire Extinguisher – Motorsport Fire Extinguishers
