LooseHeadPop
Did you get a reply?Even more impressed with the prospect of Firexo having found the range is available via Screwfix!
I think an email is in order asking whether they can be stored below freezing.
I have one at home and the answer is on the extinguisher - "Protect from Frost" The operating temperature however is -15 to +60.Even more impressed with the prospect of Firexo having found the range is available via Screwfix!
This would indicate an advisable laying-up procedure that has not come to light before; the need to remove extinguishers from the boat and store in a frost-proof environment.I have powder at the moment but, having seen the YM video I'll be changing to foam. Like the previous poster I'm put off water mist by the large number of extinguishers one would need to achieve RCD compliance.
A point to bear in mind with water mist or foam is that they can't stand freezing temperatures. It can easily get below freezing in an unoccupied boat in winter, especially if laid-up ashore. Frost proof foam extinguishers are available.
Many thanks. That rules out use on my boat. Too risky as I may forget to take them when visiting boat in the winter.I have one at home and the answer is on the extinguisher - "Protect from Frost" The operating temperature however is -15 to +60.
Sorry got distracted by other things - but I emailed them today and (without actually reading the rest of the thread!) specifically asked for clarification on the 'frost' issue.Did you get a reply?
I hope you're right, but I don't share your optimism. I've emailed them today, too.Sorry got distracted by other things - but I emailed them today and (without actually reading the rest of the thread!) specifically asked for clarification on the 'frost' issue.
I'm presuming/hoping they mean protecting from outside atmospheric conditions (e.g. the extinguisher being affected by freeze-thaw moisture) as it clearly states the operating temp of -15°C.
Not necessarily. When looking seriously at water mist, I did consider taking them all home over winter and replacing with the old powder extinguishers (which still work and have since found homes in the cars/at home).That would be tempting fate.
At least they'll know we're talking about them! ?I hope you're right, but I don't share your optimism. I've emailed them today, too.
Got a very full and helpful email back from their UK office. I won't quote it here, as consent wasn't sought in the original email, but I can summarise as follows (with my own commentary in italics!):
They're not currently accredited for marine use, but that's something they're working on (as you'd expect). They do hold all the main approvals, as shown in the data sheets. I'd imagine these should be commensurate with most of our usage/requirements. Perhaps this might disqualify coded use. Maybe even one should, technically, 'check with insurers'?
The -15°C stands and should be fine for a vessel such as our AWB, which I explained could go below freezing but would not suffer direct exposure to outside atmospheric conditions.
They won't be explicitly recommending marine use in cold latitudes until they're happy with the necessary certification, but it sounds like this is coming.
I'm more than happy with this myself and Screwfix will be supplying the mini 500ml extinguishers for both aft cabins, plus a 2l for our (forepeak) cabin for now. We already have one of PD Motorsport's lovely polished stainless (and freeze resistant) AFFFs as a 'main' extinguisher at the companionway.
Finally, after 2+ years, 'bye-bye powder' (although there's a serviceable 2kg that might end up in a cockpit locker!)
It was confirmed they had been used outside in such conditions without issue. It sounds like they can't go as far as explicitly saying they're fine in marine environments - and that's understandable, when it could mean storage in exposed locations like a RIB or deck of a workboat.Thank you. I take this to mean that the extinguisher will not be damaged functionally as long as it is stored above -15 degrees C?
If so, that would settle the matter for me too.
Given the low price of powder, replacement makes sense.I've got a number of dry powder extinguishers. None of them make any reference to a discard by date ( different brands as well). They just say to check that the needle is in the green section on the gauge and to discard safely if not.
I wonder where one finds definitive advice on powder extinguishers that are getting on a bit. It's never bad advice to replace them I suppose, but is there a hard and fast rule out there, as opposed to a good guess to be on the safe side ?
Otherwise, the only things I can think of is turn them upside down to see whether the powder is compacted and you can even/also test (fire) them quickly to check they work.
Thanks for the correction - makes sense! I did try this on a couple of small powders without gauges (triggered for a millisecond and see if it spews!). Couldn't think how else to 'test'. They're floating around in the boots of various vehicles since, but I'll dispose of them now as a precaution!I would advise against the latter. It's one thing I've seen uniformly cautioned against, but as I was curious as to the why, I eventually bothered to dig up an answer. Apart from the simple answer of "they have very little capacity to start with, and you just ate into it", with a powder extinguisher the agent can prevent the valve from fully resealing, resulting in residual leakage over time.
