SolentPhill
Well as a Fire Service bod.(retired)
re fire extinguisher for diesel, most of the comments above are sort of right, Diesel does not ignite like petrol but it will burn and it burns hot very quickly, The issue is not whether it will or wont catch fire it is what you are going to do with if it does.
Yes a burst diesel pipe will/could produce a spray a fine spray and this is lethal but no spark will ignite it, you can spray diesel on a cigerette and it will put it out, but the guy who mentioned wiring has a point a fire that has got going by spraying diesel on that will make it worse, so there is a possibility of a fire.
However lets move on to your second discussion if it is on fire what do you use, what we teach when in a fire situation? stay low its the coolest place, so whats the first thing we boaters would do if we saw smoke coming from the engine bay? open the engine hatch, well done, a great place for a back draught, and you are now at the hottest part of the fire the top, now can you hold your breath? no, can you use a fire extinguisher? no, you will thrown back and allow fumes and fire on to your boat.
So in answer an automatic system is always best, foam that will expand and cover any fire or co2 that removes air will all be good.
hope that helps.
Phill
hope that helps.
Phill
