Figure 8 loop Vs bowline
??????? You sure ?
The only similarity is the binding on standing part ...
That's what it looks like to me when I loosen it up a bit to examine it. I don't have cord to hand but I'm pretty sure that the "holding" part is essentially a sheet bend - the line goes up thru a bight and around and back under itself. Loosen it be have a close look.
.... and that is when you do a figure 8.
I thought it was well known that a bowline and sheet bend are the same knot, just formed for different purposes. The simplicity of a sheet bend doe leave some people a bit skeptical of its efficacy, so I have pointed this out a few times to reassure them.
Having said that, a sheet bend can be much harder to undo than a bowline when subjected to a heavy load. Must be something to do with the direction that the forces are applied.
I hadn't known till I looked at it. Thanks for confirming
I once had a climbing rope with a bowline unfasten itself and drop off. I was just over some difficult moves with (I thought ) about 140ft out from the belay when my second said-don't fall off-I said why is that and he said your rope has gone. It was a bowline on brand new shiny 3 strand nylon( a long time ago before braided ropes!). I think the type of rope is relevant to the optimum knot to be used apart from the application.
Repeatabilty and reliability are important as well as the knot strength.
