Robg71
yours truly with a welding stinger
ps… dont weld with a Rolex on…. Mine goes backwards….
Cracking job there and amazing progress - well worth the wait over winter! :encouragement:
I am here all day tomorrow, then work from home for a bit, (or Jersey/Guernsey) be back here again next week. meeting the team in southampton next week as well, talks with suppliers etc etc…Amazing progress. How long are you spending in Wales and how often are you planning on being there to check on progress?
Rob,
thanks very much for the pics. Looks quite large for a 50footer!
cheers
V.
Yup, makes sense, I see your point. I don't have the data on flow rates but I get your point.Mmm.... Don't want to teach granny to suck eggs, but the water flow depends also on the hose section, not just on the pressure (leaving aside other factors).
If you're saying that you backflush while the engine is running, I think that the engine pump would suck from both the fresh water hose and the seacock.
IIRC, we discussed that in the thread which I couldn't find (possibly M1 or M2 build, not sure), and agreed that even if the fresh water hose would supply less water than the pump could draw, it would still be enough for flushing.
But of course, if the pump capacity is higher than whatever the hose can supply, with the seacock left open there would be no backflush at all.
Probably also for the genset, but sure enough for your two 32 liters monsters - unless you connect a MUCH bigger fresh water hose to them?
Otoh, I'd rather not leave the fresh water hose open with the engine not running, to avoid any hydraulicking risks (albeit probably small), as you also mentioned.
Sure, such risks would be even smaller with the seacock open, but all considered, another valve would be a cheap insurance, and by sending the whole fresh water flow back through the strainer, also the cleaning is bound to be more effective...
Anyhow, I did say it was just a thought, and that it's a nice setup also as it is....
Due to lack of pump flow data, you might remember that in my maths I took the litres per hour of fuel burn in the Cats at slow idle, and calculated the heat generation from burning that fuel. Then I worked out the flow rate of water needed to absorb that heat with a 30deg C rise. I measured my hosepipe flow rate with bucket and stop watch, and computed that the water flow rate would just absorb the heat generation. I therefore concluded it would be perfectly ok to run the engines for a few minutes on a hosepipe, and of course by intuition you can be happy that there is enough water flow to lubricate the pump impellers
In those pictures I posted, the Guidi strainers are 1.25inch size as are the bronze water fittings to the gensets. The new valve I have added with the red handle is 1 inch BSP. The Guidi strainers are nice things, Italy's finest, made in cast bronze and nickel plated, but they are a crazy price
Agreed, not necessarily every bit which found its way in would be pushed out by the reverse flow, but maybe enough for a quick fix, waiting for a better strainer cleaning upon arrival.Just on the idea of backflushing of weeds, there is a fly in the ointment in that the scooper water pick ups under the hull have those cast bronze grates over them (at least, they do on my boat, but I think that is common. That will probably stop the weed being flushed backwards.
V., just as a FYI, also my 6.6 L engines have 1 1/4 intakes, so I don't think yours are undersized.BTW, if your gens are 3lt and my engines are almost 7lt then one of the two raw water intake systems is overspecified - or at least I hope mine is not underspec! I'm working on the raw water pump intake which is 1.25 so shouldn't be off the mark.
