Neeves
I have a need for some soft shackles and am sitting here with a really decent length of Liros 5mm dyneema, just braid, no cover. I have scoured the you tube threads, of which there are a lot, on making soft shackles - and it seems well within my capabilities
. I've put my task for this evening on hold pending the wisdom of the knowledgeable.
I've been playing round with the best way to feed the dyneema 'up inside itself' and there is a need for a fid. My own fids are too big for 5mm dyneema and I have fallen back on using the tube which contained a ball point pen, except this is nothing fancy just a Bic biro case. I find the end, or tip, of the biro to catch the fibres (much more easily than I would have thought) though when I touch the end of the biro its seems quite smooth.
What are the options - what do other people use or do.
I have thought of grinding the end of the biro and then polishing it with very fine wet and dry (which I'll try anyway).
Ideas would be welcome - its not meant to be that difficult.
Jonathan
Jonathan
