fender board storage
Our fender boards are actually heavy duty waste pipes. They slide over our twin whisker poles on deck but you can store them more easily than planks even if you don’t have poles to slide them over. Lighter, don’t rot, strong.
Great idea! what diameter? looks like 6".
Oh gosh I can’t recall but yeah about that. The lines that we tie into the guard rails are Pulled inside the tubes so we don’t have to tie them on each time. They can roll against the harbour wall and fender a little also which reduced chaffe / pulling on the fenders.
What do you do with them when you are using your whisker poles?
Leave them on deck inside the guard rails tied in with the same lines when they’re used as fender boards. Whisker poles don't come out that often as we have a spinnaker pole also which is rigged to the mast.
