Colin K
Hello,
I have been rebuilding a Farryman engine to my genset for about a blooming month in my spare time as we are off for three weeks soon. And thanks to everyone who has helped me along the way.
All ready to put the side panels on and transport it to the boat and I thought it might be a good idea to run some water through the notorious water ways to make sure they run ok. I disconnected the feed into the injector manifold as I figured this might pump water back towards the cylinders?
Turned on the water gently and found a decent weep of water coming out of the head/pot joint. I took the head off and found this is coming from the four head/pot bolts which go from the enging lump through the pots ,through the head and then head nuts on top. Using a cable tie I now find that the bolts are open to the pot waterways! I recon this has come about through corrosion inside the casting?
I guess I could seal the bolt passageways where they go through the casting making sure I did not pump too much sealant into the water way! And then seal the head joint with sealant as well? Or I could just give up and have a holiday without 240v when at anchor and save carrying 50 kg of weight around with me. Hey more beer space in the laz, lazer, lassere................boot.
Wondered if this problem is a popular one to any of you chaps who know their Farrymans?
Thanks all again, Cheers, Colin.
