Fairwinds homeward-bound
machurley22
19 Jan 2004
Scotland
Webcraft & Retriever departed Terceira yesterday towards Camarinas.
Position report 2000 UTC July 9th
Departed Wossname 1230
N38 57.5 W26 27.5
Distance travelled 35nm
Distance to somewhere else 815nm
All well, doing about 4.5kt in light winds.
Will report noon tomorrow.
Fairwinds' Position Report 12.00 UTC 10th July 2007
39deg 26.9'N
024deg 51.7'W
Distance from Praia da Vitoria 115nm
Distance to Camarinas (approx) 740nm
Left Praia at half past twelve and have done 115nm on a direct track (great circle route) for Camarinas. We left twenty minutes before Will on Aluffe - he has two Kiwis as crew for this leg. They overtook us during the night and are now several miles ahead of us, out of sight but still VHF range.
We talked to a couple of French boats last night who have been listening to Herb's 'Southbound' Atlantic weather net. Herb is recommending that boats bound for Europe from the Azores stay below 40degN until Friday as there is a strong depression at 43degN. We will probably taked his advice and head due East when we reach 40degN early tomorrow morning; winds are light, seas calm and the sun shining at the moment, but a front with 20-25 knots will pass over us on Thursday or Friday, bringing stronger NW winds behind it.
Having said that, I have just looked at today's GRIB and it si showing the depression weakening and slipping South now, giving us more strong South-Westerlies early next week . . . . Plan B may be Bayona, it's a little bit nearer. It doesn't look like it's going to be a milk run anyway . . .
We had a bit of a problem with the VHF this morning - there are not one but
two dodgy connections in the mike lead, so it has to be bent at a strange
angle to get it to transmit. Otherwise things are fine, although we are
having to run the engine more than we would like to charge the batteries.
Fairwinds out.
Position report Tuesday 2041 UTC
N39 32.4
W24 07.7
Sailing at 2.5kt in light winds. Currently making more West [for West read East] than North to avoid a developing front, expected to pass through Thursday/Friday. Once this has passed will start to head on a direct track to Finisterre.
More tomorrow.
machurley22
19 Jan 2004
Scotland
Fairwinds' Position Report 12.00 UTC 11th July 2007
39deg 40.7'N
022deg 36.1'W
Noon - Noon Run:108nm
Distance from Praia da Vitoria 221nm
Distance to WP B1 221nm
Distance to Camarinas (approx) 635nm
At 1300 yesterday after consulting the GRIBS we decided to heed Herb's advice and stay below 40 deg N until the front predicted for Thurs/Fri has gone through, thus hoping to avoid the strongest winds. We therefore altered course for a waypoint (B1) at 40 deg N 17deg 50'W, a distance of about 340 miles from our then current position.
In the evening we tried to listen to Herb but even with the external aerial on the Roberts SW receiver there was too much static. Spoke to Lady Ann on the VHF - she had been speaking to Herb and he was predicting 15 knots for Wednesday and 25, maybe a bit more, for Thursday when the front came through, after which we would be able to turn for our waypoint for Finisterre or La Coruna. By then there should be about 400 miles to go.
It was a roasting hot day with only a few knots of wind aft of the beam - the hottest we have ever been at sea on Fairwinds. Luckily it was calm enough to open the forehatch for some of the day. We managed to sail at a bit over four knots for most of the time, although it slowed down a little bit after midnight. Kathy kept sailing slowly so I could sleep, but at three o'clock when I came on watch I put the engine on, and we motor-sailed at up to 6 knots for the next nine hours. I topped up the diesel at ten thirty - eleven litres filled the tank to the brim, with another 40 litres in cans still in reserve.
This morning we heard Lady Ann calling up a US warship (which passed us maybe half an hour later) on CH16 and asking for the weather. They gave 15-20 knots, cloudy and 3-5ft seas for today. As I write this it is hot, the clouds have gone and we have about ten or eleven knots of wind from the SW . The genoa is poled out and we are rolling along peacefully at between four and four and a half knots.
Fairwinds out.
machurley22
19 Jan 2004
Scotland
Jist had a call from the man hissel' on the satphone. His opening comment was "This is scary [--word removed--] Dave, you don't want to do anything like this ever!"
On top form however - goose-winged, poled & prevented and making a stately 3.5 knots but coming under some pressure from the first mate (Are we nearly there yet? I thought you said this boat could make 6.5 knots?) to do a tcm and fire up the iron topsail.
This looks like it might be their first proper downwind passage of the entire trip - touch wood, scratch a backstay and turn three times.
<span style="color:green">Jealous? Who me? Never! </span>
machurley22
19 Jan 2004
Scotland
Fairwinds' Position Report 12.00 UTC 12th July 2007
39deg 51.4'N 020deg 28.1'W
Noon - Noon Run:102nm
Distance from Praia da Vitoria 322nm
Distance to WP B1 121nm
Distance to Camarinas or Bayona (approx) 540nm
We had a good sail poled out and goosewinged until dusk, at which point I spoke with Lady Anne to see what advice Herb had given him. It was the same as before - maintain a course below 40degN for another 36 hours (i.e. to Friday morning sometime) before heading directly for Finisterre. Herb had suggested winds building overnight, so we dismantled the bits of string and downed the main - only to find there was not enough wind to run under genoa, so we motored overnight for nine hours in light conditions with 3-5 knots apparent from astern.
At six o'clock we switched off the engine and deployed the genoa, then at nine put the main back up - with two reefs in this time - and ran goosewinged. We have just checked the new GRIB and it looks like no change - we can expect the SW wind to build to twenty to twenty five knots overnight, before dropping away again sometime on Friday morning. I have just gybed the pole to keep us on track for our intermediate waypoint at 40N. We will get the main and pole down again at dusk or when the wind gets near 20 knots, whichever comes first. At the moment we are surfing at up to seven and a half knots, and the Navik is still coping - just.
Fairwinds out.
(Note that the image is no longer north up since the placemark labels were getting a bit confused.)
machurley22
19 Jan 2004
Scotland
Friday 13th!
Fairwinds' Position Report 12.00 UTC 13th July 2007
40deg 00.0'N 018deg 10.2'W
Noon - Noon Run 113nm
Distance from Praia da Vitoria 435nm
Distance to Camarinas 442nm
We had a fantastic downwind sail goosewinged yesterday afternoon (latterly with both sails reefed) but we took the pole and main down about four o'clock when the wind (temporarily as it turned out) gusted up to 25 knots.
After a few slower hours under genoa wishing we had left the main and pole up a bit longer the wind we had been expecting arrived, and by midnight we were surfing at up to nine knots. The skipper was soaked by a rogue wave that came aboard uninvited, and a sizeable percentage of genoa the was subsequently rolled away. A mad downhill sleigh ride in building seas continued through the night, with neither of us getting much sleep as the motion was pretty violent. At dawn the wind was constantly over 25 knots with no sign of a reprieve. Then it began to rain, and the wind dropped and the seas calmed. The rain stopped, and we had thirty knots of wind again, then rain and calmer seas again, then more wind.
Suddenly at 0730 UT - instantly in fact - the wind switched from 25 knots SW to 25 knots NW and the sea went mad, turning into a witches cauldron of chaotically frothing peaks and breaking lumps. Going on deck looked like a dodgy proposition, so we waited half an hour for things to settle down while the blissfully unaware Navik sailed us South.
We seem to be out of range of Lady Ann, so no more second hand Herb for us - but his advice on this front was certainly sound - we would not have liked to have encountered it further North where it was quite a bit stronger. It may have taken us thirty miles or so out of our way, but we think i was worth it.
Since then we have had a light Northerly wind, and as I write this the sun has come out again. We have crossed 40 deg N and are on a direct track for Camarinas, although how and where we eventually close the Spanish coast remains to be decided nearer the time - we will have to avoid the Finisterre TSS for one thing. Looking at the latest GRIB we also need to plan to get in somewhere by Tuesday night as there may be NE winds developing off the Galician coast by then, becoming strong towards the end of the week.
Fairwinds out
Sounds like a lively 24 hours.
