F10 in Ostend or 'Is toerail expensive?'
Koeketiene
24 Sep 2003
Finistère
www.sailblogs.com
F10 in Ostend or \'Is toerail expensive?\'
Koeketiene
24 Sep 2003
Finistère
www.sailblogs.com
Re: F10 in Ostend or \'Is toerail expensive?\'
It's Guapa /forums/images/graemlins/frown.gif
Deck's not a worry - will be ripping it out in a couple of weeks anyway.
Just the toerail - are these things expensive?
wingdiver
12 May 2005
Eastern UK
WWW.MYSPACE.COM
Bound to be - it's marine innit! /forums/images/graemlins/frown.gif
Hope you get things sorted.
Been a bit of a year hasn't it.
Cheers
D
Gwylan
31 May 2007
Moved ashore
Where were you in Oostende?
Sadly sure to be expensive, if it says 'marine' or 'boat' or 'nautical' Pity caravans do not need toerails, that could bring the price down.
johnalison
14 Feb 2007
Essex
It's always sad to see any damage (excluding jet-skis), but I've never liked fairleads much. I doubt if the braided line has much give in it and suspect that proper dock lines might have given a bit of a chance.
Sixpence
24 Aug 2005
Here, yah fule
Oh crap, that's not a nice site to see /forums/images/graemlins/frown.gif
Cost of toerail is (not surprisingly) outside my budget, and as far as I can find with searches, no, it aint cheap
Another broke boat on here, sorry Will, but it's going to cost a lot to fix a bit, far as I can tell you have to replace the whole length /forums/images/graemlins/frown.gif
Koeketiene
24 Sep 2003
Finistère
www.sailblogs.com
Spent two weeks there - happened the WE before last.
NW 9-10 at HW
Koeketiene
24 Sep 2003
Finistère
www.sailblogs.com
Well - you suspect wrong.
The 'proper' lines broke - only prompt HM and nearby maritime police action prevented worse. They used whatever was available.
Athene V30
20 Sep 2001
Playa del Ingles, Gran Canaria in Winter, the boat
Is there an alternative to replacing the toerail. Do you need toerail forward of the aft most stanchion for the pulpit roughly level with your anchor windlass?
If not could you not cut it off both sides and just fit a couple of large fairleads where the damage is.
FullCircle
19 Nov 2003
Jeez, sorry for you Will!
I think the main problem will be matching the old section, which will mean changing all of it.
Can I suggest you have a strengthening stainless plate which goes under the (much larger section) fairleads you will replace them with, then carry the plate aft and turned up with a neatly rounded flange, back to the stanchion area, where you can blend the toe rail back in.
That way, you get extra strength, and don't have to replace the toe rail, which might be unmatchable anyway.
Jomo
10 Oct 2004
Me:Leicestershire UK, Boat Ipswich
NW 9-10 at HW
wondered where Guapa was.... mooring always empty when I've been down recently.
Another hit on a bad year! roll on next, hopefully see some improvement.
Gargleblaster
16 Dec 2003
Medway, Gillingham Reach
I have wooden toerails and one broke last year during a knockdown as the whole boat flexed. I looked into replacing my complete toerails with aluminium toerails. Can't remember the exact figures but it was over £2,000 just for the extruded section and as I was looking to have some one else do it as I am useless with my hands, I discarded that idea. Had our club amateur chippy replace the broken bit, which was half the toerail on the port side in teak that he found in the boatyard. Still cost me over £300 for his labour and his charges were not exhorbitant.
Long answer to your question, but I think it is costly but you might be able to get away with having a section welded in by a professional aluminium welder. Have you talked to your insurance company?
FullCircle
19 Nov 2003
Trouble is with welding alloy is that a 20 tonne alloy becomes a 6 tonne alloy post welding, so it is a limited option.
CPD
20 Sep 2006
Hampshire
No meaningful help from me Will, but hope it gets sorted for not too many sheckles.
If you can remove the whole strip then I would have thought it possible for a careful metalworker to bend her back to shape ?.
Koeketiene
24 Sep 2003
Finistère
www.sailblogs.com
I'm hoping it's fix-able - the whole strip needs to come off anyway.
Boat's on the hard now. Will be speaking to a friend who used to run a shipyard (built Inspiration and Spirit yachts). He's pretty well connected - hoping he knows some-one.
I have informed GJW about the incident and told them I might/might not make a claim. If it's fixable on the cheap (not substantially more than my excess - £500) I won't claim. Will see what the options are.
bastonjock
23 Jun 2007
Lincolnshire
sorry to see the damage wil,hope that its not too expensive,my new mast and bits including rigging,cdi furler,shrouds etc comes to 1500.00
this boating lark sure sucks the dosh out of the old bank account
Koeketiene
24 Sep 2003
Finistère
www.sailblogs.com
And finally - some good news.
It seems the toe rail's made by Goiot - still in business.
Made in 6m sections. Just one complete section needs replacing (from port middle fairlead forward) and one new fairlead.
Starboard side everything can be salvaged.
So, €600 should take care of it.
Amazing what passes for good news these days - only €600.
Could have been worse I suppose.
