Kukri
Death to back splices for slip lines.![]()
On this, we can all agree!?
+1to believe that the first method that they use to attach a warp should by the final one, but not necessarily, once the boat is secured,
Kind of depends which end. Certainly not on an end being cast of, as that is asking for trouble. But IMHO fine for the boat endTeaching several hundred sailing school students over a couple of decades has taught me to never, ever have a loop in the end of a dock line.
However, it's personal choice. ??
Or perchance people tie up differently for different circumstancesThis works well when you secure to a floating pontoon.
It doesn't work well when you're tied up to a pier or harbour wall and there's tide to contend with.
We seem to live in a world where no-one ties up in tidal areas anymore unless they're tied to a pontoon that floats with the tide....
I hope they do.Or perchance people tie up differently for different circumstances![]()
The OP asks about the possibility of using seizings instead of a traditional tucked splice to make an eye. And immediately the thread devolves into how everyone else but me ties up wrong.
Doesn't this bother anyone? Tie up threads always devolve this way.
I find these discussions just an exersize in one upmanship. In my observations, the only boats that come lose are the result of chafe.
Sorry, but where did I ever ask about “using seizings instead of a traditional tucked splice”?
There must be some Transatlantic misunderstanding taking place here, because I simply asked whether people used soft eyes on shore lines, and nobody else saw any reference to seizings.
I can only assume that you read my reference to whipping the end of a rope as a reference to clapping on a racking seizing, an operation which I am well able to do after forty years of gaff cutters, (leading to a working knowledge of the works in literature of Messrs Ashley and Toss), but which was never in discussion here.
In British English, a whipping is what you put on the end of a single rope to stop it unlaying and turning into a “(rather offensive term elided) pennant”, a seizing, either flat round or racking, brings two ropes be they fibre or steel together permanently and an eye splice is a means of forming an eye in fibre or steel rope in which the strands of one are tucked into the other.
“Two nations divided by a common language!”?
I believe the Royal Navy used to use the term "Irish Pennant"Sorry, but where did I ever ask about “using seizings instead of a traditional tucked splice”?
I believe the Royal Navy used to use the term "Irish Pennant"![]()
No, not a transatlantic thing. I thought you meant that you were going to cut out the bad bit (chafed eye on end) and replace it with a seized eye (which you mistakenly called a whipped eye, a common error, but one you did not make). For what you were asking, it would have simper to say "My old dock lines are worn out. Do I need an eye in my new dock lines?" Just lazy reading on my part. My nautical English is just fine.
No, a racked eye is nowhere near as strong in nylon (about 35%) as a splice and not as reliable as a knot in nylon specifically. I challenged several well known riggers to make them, I pulled them to failure, and they were surprised. Nylon shrinks in diameter when pulled, the seizings become loose, nylon is slippery anyway, and the rope slowly slips through. A knot is better and a tucked splice much better. Pull each to failure and see. In polyester a racked eye does better.
Eye vs. not, and tieing up in general, is still a conversation that has been done to death.
Some extra cleats would also make life easier.A lot of yacht mooring seems to involve trying to put a lot of quite big rope onto quite small cleats.
On my boat, it seems easy to run out of cleat. I don't really want to use smaller warps.
Some spliced eyes might make life easier.
I have had the same line for 18 years & no visible sign of chaffe. I never anchor & always use marinas. I spend 5 months of the year away from my own marina, so tie up to lots of different places. Being SH It makes perfect sense to bring the line back to the boat. The only time I might not do it is if I am on long stay in rolly places such as Ostend etc . Or if my bow line is not long enough. That one is deliberately short so that if it falls in the water when entering port it will not reach the prop.Lines from boat to the pontoon looped round (or through) a cleat and back to the boat are a real pet hate of mine. Why chafe the line in the middle in such a crass unseamanlike way? Lots of people do it but it’s lazy and poor seamanship IMHO. Secure to the cleat (in such a way that it doesn’t use the entire cleat up and stop somebody else using it) and have all the spare line coiled neatly on board the boat.
When you want to leave rerig the line as a slip. If I’m only staying for a few minutes I might leave the line looped around, but never when I leave the boat for any length of time.
(PS And I’ve sailed with Tom Cunliffe and he doesn’t talk bollox. I sail in the real world and I also generally try to use one line for one job. )
