Exposed fiberglass under waterline
kingsebi
6 Nov 2020
I hit a sandbank today. Quite a bump. Luckily no serious damage. I dived and the impact scraped away antifouling and gelcoat over a small area at the front of the keel. The fiberglass is exposed but intact. Should I haul the boat out as soon as possible? What is likely to happen if I don’t? The boat is a Trident Voyager 35 with full encapsulated keel and thick fiberglass layup. Thank you for any advice.
greeny
15 Jun 2004
Portugal
My imediate thoughts would be lift, wash, dry out thoroughly and re gel. Then epoxy primer and anti foul. What will happen if you don't? Water ingress into the glass lay up leading to other problems and the affected area getting larger as time goes on. Will the boat sink - no. So either do it soon and its a small job or leave it and the job may get bigger and more difficult.
LittleSister
12 Nov 2007
Were you really able to confidently tell from your dive inspection that the GRP layup was completely intact? When were you next going to take the boat out of the water otherwise?
With an encapsulated keel and iron or steel ballast (the norm) it is vital that the GRP 'seal' remains intact. A hole or crack can lead to water reaching the ballast, which then rusts, which expands the ballast and can force outwards the GRP shell of the keel, eventually leading to major cracks which exacerbate and accelerate the problem.
If caught in time this is unlikely to be a major problem, but can in some cases eventually get to be so costly and difficult to rectify that the boat becomes a write off.
kingsebi
6 Nov 2020
Thank you for the input. I understand about the ballast rusting. I thought the same. Better fix it right away. Too bad, the plan was not to take the boat out of the water for two years.
Trident
21 Sep 2012
Somewhere, nowhere
If you have somewhere you can dry out, scrubbing piles, a beach etc you could fix it between tides. You can clean and check the glass, if its cracked etc then go to haul out. If not just acetone and mix up some flow coat with a decent amount of kick and maybe some help with a hot air gun or hairdryer if you have power and it will set off in a couple of hours completely waterproof . You may even have time to sand and polish it before it gets wet again
RunAgroundHard
20 Aug 2022
Likely there will be no issue with the boat as the encapsulation lay up will be very thick. The exposed GRP will not absorb water, so you can leave. However, boat lifts are not booked up at this time of year, so easy to get a lift out. Once spring approaches I find that they are unavailable for a long time.
kingsebi
6 Nov 2020
The lay up is very thick indeed. Thank you, I was not sure if the exposed GRP would absorb water or not. Anyways I guess it will be best to address the problem right away.
AntarcticPilot
4 May 2007
Cambridge, UK
www.cooperandyau.co.uk
I think that if the glass cloth was fully saturated with resin during the lay up, it's ok. The risk is that the glass might not be fully saturated, allowing water to wick along the fibres. Given that the layup in question is in a part of the mould that is difficult to reach, being both narrow and strongly curved, there must be a possibility that the layup was not as well saturated as it might be elsewhere.
ghostlymoron2
12 Sep 2023
Inform your insurers, it's an accident against which you should be insured. Book it in for repair. Why do it yourself?
My insurer was very helpful with advice when my boat dragged and drifted into rocks.
kingsebi
6 Nov 2020
Thank you. That is an idea. I didn’t think about that.
I had another look in clear (albeit a little cold) water and I’m positive that there is no damage to the GRP, it is just exposed over a small area of some square centimeters. Whatever I hit I was lucky.
Once in Crotone I will ask the crane operator if he can keep the boat in the slings for a couple hours, enough time to put on some epoxy and antifouling.
