Mike_02
OK..here is a good one for you all.
As soem of you may know i have a Dophin Petrol Engine. Now this has a dry exhaust as it's keel cooled.
My current exhaust is 3 meters of 28mm copper pipe. The problem is that it has several compression joints in it. This type of plumbing setup is not designed to get this hot and therefore it works loose. So the end result is that some of the joints part company on a regular basis.
What i want is something flexiable that is no larger than approx 28mm and can take the heat...(car exhaust temps).
I can find anything...HELP..!!!!
