peters.carl
I have an exhaust outlet in the stern of my 26ft cruising keelboat boat. With the boat in its marina berth it sits about 80-100mm above sea level. With the boat underway it sits below the level of water at the stern because of the stern wave. The engine runs fine and pushes water out under pressure, and we have a riser to prevent ingress, but is this putting extra back pressure on the exhaust and should I raise the exhaust outlet? Is this a common problem? How high does the outlet need to be? I guess above the level of maximum waterline with the boat underway?
Many thanks
Many thanks
