Same as came with the motor. I think the problem arose as I wasn’t able to use both slow and fast wipe wires. I chose to connect the slow wipe and leave the fast wipe disconnected, result blown fuses. Connecting the fast wipe and leaving the slow wipe disconnected works ok, although I can’t see why. Perhaps it would be good to include instructions for connecting the motor to a single speed switch in the manual.
I got the second motor wired in this afternoon. Both work but well out of sync and still the odd blown fuse. I think I’m going to have to fit this controller to get things working right.Or ideally you would use new controllers... Is it one of these? It came up when i googled the motors.
Exalto LD Wiper Control | Force 4 Chandlery
That's a lot of money to pay just to make the wipers move in sync. Regarding the fuse blowing, what fuse rating was there originally and what do you have now?I got the second motor wired in this afternoon. Both work but well out of sync and still the odd blown fuse. I think I’m going to have to fit this controller to get things working right.
Deepest joy ?
The original for the old motors was 10a, the new motors are rated for 5a and comprehensively blow 7.5a. There are other advantages, two speed and intermittent wipe and helm wipe only, just going to be a pain running the cables. I might as well bite the bullet and do the job properly now I’ve gone this far.That's a lot of money to pay just to make the wipers move in sync. Regarding the fuse blowing, what fuse rating was there originally and what do you have now?
So I assume you have two 5A fuses, one for each motor on separate supplies? Otherwise a singe 10A as original using the original supply cable.The original for the old motors was 10a, the new motors are rated for 5a and comprehensively blow 7.5a. There are other advantages, two speed and intermittent wipe and helm wipe only, just going to be a pain running the cables. I might as well bite the bullet and do the job properly now I’ve gone this far.
Waste of time on a boat without a civilised roof perhapsThe whole idea of having a motorboat is to go fast enough to avoid bad weather / rain. Wipers are a complete waste of time. Never rains on the Isle of Man anyway!
Waste of time on a boat without a civilised roof perhapsMost of the water on the screen comes from waves deflected by my awesome bow flare then blown back by the never-ending bloody wind here
I see they shifted that wreck from Gansey this afternoon.
No, Kalik 40 South Korean built according to the guy who sold it two weeks previously. Looked like a nice boat before its tangle with the Carrick.Herd that was happening. One off build yacht apparently. ??
I’ve actually been wetting the screen for this reason. I just think the motors aren’t designed to run off a single one motor switch which I hadn’t realised when I started the upgrade.I had a similar issue, I put it down to the wipers operating on dry windscreens when testing the current draw and I uprated the S/S springs in the wiper arms to give more pressure holding the blade to the glass.
Local sources suggest it was bought by Pol Pot’s grandson and was being sailed by Robin Knox Johnson. Of course this is crap, Pol Pot didn’t like boats…that’s IOM jungle drums for you….a bastion of accuracy ??
Looks like my B+ AIS transponder will have to wait a while longer…?
As thought the cabling disappears into the bowels of the boat somewhere. I pulled down the wood panel ceiling trim and drilled a hole through into the space where the helm wiper and light is. My cables will run directly from the wipers to the helm switch in the ceiling void ?Sorry to hear the wiper job has rapidly escalated!
I might stick with the single blades for a bit longer but keen to see the outcome of your project ? ? ?
Sorry for resurrecting a thread from the dead but I wondered if you ever ended up fitting the new Exalto controller to stop blowing fuses on the panto wipers?As thought the cabling disappears into the bowels of the boat somewhere. I pulled down the wood panel ceiling trim and drilled a hole through into the space where the helm wiper and light is. My cables will run directly from the wipers to the helm switch in the ceiling void ?
